Poser - OFFICIAL F.A.Q (Last Updated: 2024 Nov 09 6:42 pm)
Unzip the zip file. You'll find a bunch of OBJs. Put them somewhere where you can find them again.
In Poser, load up Emotiguy. Select his head. Click on the Properties tab (in the Parameter Dials palette). There's a button that says "load morphs," or something like that. Click it. A new menu will come up. You can browse to find the OBJ, and name the morph. (The default is "shape1," but I recommend giving it a more descriptive name, such as "Sunflower" or "Heart.")
Repeat for all the morphs you want to add. They will appear as dials in Emotiguy's head, and when you set them at 1, you'll see the new shape. Save the new Emotiguy to your library, and you'll never have to add the morphs again.
These instructions are for Poser 5, but it's similar for P4. (You can also load morph targets using the "Object" pull-down menu.)
If you're using PP on a Mac, this might not work. Apparently, that version of Poser has trouble with this type of OBJ file.
I hope this doesn't sound stupid, but would someone please explain how I use the emotiguy morphs in poser? I've never used morphs outside of "premade character type packages" before. Thanks, Virginia.
