Tiny, Not too sure about sharing these. Nothing is in the standard file structure of Poser. Textures and OBJ files are in folders that I can keep up with and not even in the Poser folder. After I get everything done..still want to do my gransparents house..I might consider setting the models up in the proper file structure. Doing something like this is really easy once you understand how modeling something like this in Poser works. The framework for the garage only took about one evening..or a couple hours. I got started doing these after I followed Doc's tutorials and enjoyed doing them because I was actually learning something that not too many people would try. Give it a shot, you might see how easy it is.
cherokee69,
What you should do instead of locking the dials is make them invisible, that way if someone wants to use them at some future date they can.
Once you save the figure as a pp2 or cr2 open it up in an editor (I use UltraEdit) & scroll down until you get to something like this for each door....
translateX xtran
name GetStringRes(1028,12)
initValue 0
hidden 0
forceLimits 0
min -100000
max 100000
trackingScale 0.002
keys
static 0
k 0 0
interpStyleLocked 0
translateY ytran
name GetStringRes(1028,13)
initValue 0
hidden 1
forceLimits 0
min -100000
max 100000
trackingScale 0.002
keys
static 0
k 0 0
interpStyleLocked 0
translateZ ztran
name GetStringRes(1028,14)
initValue 0
hidden 1
forceLimits 0
min -100000
max 100000
trackingScale 0.002
keys
static 0
"hidden" is the control for dial visibility. 0 is the default, just change it to 1 and the dials disappear.
Message edited on: 02/10/2005 12:25
Attached Link: http://www.renderosity.com/viewed.ez?galleryid=888925
Carolly, if your referring to the doors on the front..each is a separate door and are posable. The center door is behind the left and right door. the above link is what I have so far.Message edited on: 02/20/2005 13:14
OK... THAT explains it! Side-sliding doors (went back and looked at #3 again). Better lighting (like when it is used in a scene) would show depth... but that was a test render. BTW, your 64 Impala... my parents got a red and white '64 Impala Super Sport convertable when I was a kid. Totally the wrong sort of car for a family. It drove like a boat (that was what I learned on), but it had style. Carolly
'64 Impala Super Sport convertable --- WOW, definately not a family car. My grandfather's (mine now) is a '64 Impala 4DR HardTop..that's the one that doesn't have the center post between the front and rear doors. As soon as the weather improves, I'm goin gto get it out and do some needed work on it.
Message edited on: 02/09/2005 13:22
