Sun, Feb 9, 11:00 AM CST
Subject: User objects file corrupt :(
Trel ( ) posted Sun, 20 February 2005 at 3:29 PM ยท edited Sun, 09 February 2025 at 10:39 AM
My user objects file is corrupted C:Program FilesCorelBryce 5PresetsObjectsUserUser.obp is there any way to repair the above file? I think it happened when it got inturrupted while adding a object to it :(
GROINGRINDER ( ) posted Sun, 20 February 2005 at 4:15 PM
At this point most people end up deleting the user.obp file. I usually back up each object individually as I go along so that I can rebuild when this happens. If you backup all your user obp's as one file, it is humongous. I think this happens because windows does not defrag the obp files when it defrags.
Trel ( ) posted Sun, 20 February 2005 at 6:12 PM
well luckily, I still have the origional bryce saves I added the objects from, so I have that option. Deleting the file will cause it to be rebuilt right?
ysvry ( ) posted Sun, 20 February 2005 at 9:50 PM
why do u think that groin? is there something special about that file? windows just sees zeros and ones me thinks. i think bryce messes up itself if the file gets too big. read something along these lines in previous threads about corrupted User.obp files as it happens often
for some free stuff i made
and for almost daily fotos
Zhann ( ) posted Mon, 21 February 2005 at 1:42 AM
Remeber for each thing you delete from a object category that you are only deleting the thumb for that object and the 'actual' object stays in the category. When the file gets too big Bryce goes wonky on it and you find you have corrupted obp files. You are also limited to only 36 objects per category, if you get bigger than that the file gets weird, better to create another category. How many categories(i.e. my objects, their object, dl objects etc) did you have under user? Or how many objects were in your user.obp?
Bryce Forum Coordinator....
GROINGRINDER ( ) posted Mon, 21 February 2005 at 3:29 AM
If you delete from within Bryce, then you are only deleting the thumb. If you browse to the folder in windows then delete the user.obp file you will delete the whole enchilada so it can be rebuilt from scratch. The reason I say windows does not defrag the files is because windows defrag tells me so with an error message each time I run it. Am I the only one experiencing this message??
Zhann ( ) posted Mon, 21 February 2005 at 4:05 AM
I defrag once a month and have never rec'd a message about those files, go figure
