Poser - OFFICIAL F.A.Q (Last Updated: 2024 Sep 19 11:01 pm)
unles I am wrong, the "anti-alias" feature in Poser5 is only available with the Poser4 render engine. The FireFly engine gets rid of choppy edges thru other controls such as MinShader Rate. If you use FireFly, your image WILL be choppy in draft...you've got to turn on "production" to get hi-res. It's a very good idea to "render to another window" and then when you save, save to TIFF or PNG to get an 'alpha channel" which means when you open the image in a 2D graphics package, the background can be dropped away. That's pretty quick and dirty, others may elaborate. ::::: Opera :::::
Attached Link: http://www.keindesign.de/stefan/poser/renderer.html
See the link for more info on what the parameters in P5 Firefly are typically used for.Tools : 3dsmax 2015, Daz Studio 4.6, PoserPro 2012, Blender
v2.74
System: Pentium QuadCore i7, under Win 8, GeForce GTX 780 / 2GB
GPU.
I just got Poser 5, and over the past couple of days I've grown, but I have a couple of questions. One problem, after I render and save my image, it's coming out with very choppy edges, even though I used the "antialias" function before I rendered the image. Is there a way to make the final image smoother? Also, is there a way to save it with a transparent background? Thanks, novelist999
