Bryce F.A.Q (Last Updated: 2024 Nov 12 7:03 am)
Attached Link: http://www.renderosity.com/viewed.ez?galleryid=890573&Start=1&Artist=bazze&ByArtist=Yes
drop my a comment in my gallerywww.colacola.se
Attached Link: http://www.colacola.se
Download the model, the pilot and the textures from my site (www.colacola.se) Hope you like it!www.colacola.se
I am beside myself in awe...
<strong>bandolin</strong><br />
[Former 3DS Max forum coordinator]<br />
<br />
<a href="http://www.renderosity.com/homepage.php">Homepage</a> ||
<a href="http://www.renderosity.com/mod/sitemail/">SiteMail</a> ||
<a href="http://excalibur.renderosity.com/mod/gallery/browse.php?user_id=70375">
Gallery</a> || <a href="http://www.renderosity.com/mod/freestuff/index.php?username=bandolin">
Freestuff</a>
<p><em>Caution: just a hobbyist</em></p>
abosultely bl**dy marvelous, well done
Experience is no substitute for blind faith.
http://avalon2000.livejournal.com/Â -
My Art Blog
The elevators need to be remapped. You can do this by using the right click menu and using "select by geometries", then assign them to right and left aileron. You would then have to use planar mapping with the split option to get the top and bottom halves. Then place the bottom aileron halves with the bottom wing, and the top aileron halves with the top wing. Now the top will not bleed onto the bottom. This happens when you split the wing mapping, but not the aileron mapping. If bazze does not post the remap, I will ask permission to do it.
thanks guys. Groingrinder if i knew what you were on about i would give it a go but being one of the many new users to bryce i'm not yet fully up on doing things like mapping. I can wait till you do the remap. can't spend to much time on here today. got some charges to lay later so need to count them out as well as the leads and dets.
If you map the thing before cutting off the ailerons, it probably wouldn't have that problem. (At least I know that's how the UV mapping works in Wings.) You might have to try that...
Attached Link: http://www.renderosity.com/viewed.ez?galleryid=890855&Start=1&Artist=lebla312&ByArtist=Yes
Looks like it has been hijacked tp PovRay by the rebellion :)www.colacola.se
I believe on Earth analog 17913 or E'arthss as it is known the Comordian Reich is winning and the pilots are actually reptilian. The same ones BTW who made it to Earth(prime) in 1947ESY (earth standard year) through an alternate reality "Philadephian Project" and are now in top public offices. Just and FYI Nice model Bazze
www.colacola.se
