Mon, Feb 10, 10:28 AM CST
Poser - OFFICIAL F.A.Q (Last Updated: 2025 Feb 10 9:40 am)
Subject: New PC.. WOW (IS related to Poser)
raz ( ) posted Wed, 23 February 2005 at 10:24 PM · edited Wed, 05 February 2025 at 8:13 AM
well, i broke down, upgraded to a 64 bit system.
here's the specs.
DFI mobo
Athlon 64 bit 3400 CPU
2 GIGS cor$air memory
256meg video card
Umm, my system wasnt zaktly the slowest or oldest as it was.. but I gotta say, I can render FAST (not just 'seconds',- - really noticable).
am 'preparing' for P6...figured I'd amp up what I had.
XP home isnt 32bit, so I really wondered about any diffs... thing is, I can multitask and the PC dont bog at all with 5 (count em... FIVE!!!) memory hoggin apps running all at once.
My last system specs, an Athlon (32bit) XP 2500, 1 gig cor$air, and the rest of the same parts was "fast" too, but I couldn't multi-task without taxing the system.
A specific Poser related thingy is "global lighting" with several shadowmaps.. when there was a large amount of lights, when I rendered it, each shadowmap set to 1024 would take 2-3 seconds for the progress bar to go and switch to the next light...NOW, using the SAME global light setting, a render will instantaniously "zip! zip! zip!" faster than I can type it out, through all the lights with shadowmaps, then render faster too!
havent 'measured" the actual render "draw" in the window for time... but I can tell this was all "worth it".
just FYI..
Message edited on: 02/23/2005 22:26
operaguy ( ) posted Wed, 23 February 2005 at 10:44 PM
Attached Link: http://www.renderosity.com/freestuff.ez?Form.Contrib=Jim+Burton&Topsectionid=0
Would you be willing to run Jim Burtons Poser5 time trial? That would be usefull to all of us. ::::: Opera :::::
raz ( ) posted Wed, 23 February 2005 at 10:57 PM
Yes I would, but No p5 here... I will run his other tho! Be more than happy to!
raz ( ) posted Wed, 23 February 2005 at 11:20 PM
Well here it is. I ran this before the new system, so I cant "compare" (dont have P5) PPP Jim Burton's time trial was 31.02 seconds with his settings in the PZ3. (no changes on my part) the pic was resized to fit in here...
leather-guy ( ) posted Wed, 23 February 2005 at 11:49 PM
Pretty darn good! I just ran the same test and it took 71 seconds. . . (P4 - 3Ghz 1 Gig Ram)
raz ( ) posted Wed, 23 February 2005 at 11:59 PM
wow, really? it did seem faster , but I never checked b4 the upgrade... Im happy
Dale B ( ) posted Thu, 24 February 2005 at 7:29 AM
And just remember, kiddes, that '3400' is the PR rating, not the clock speed....which I =think= is still under 3 ghz.
geep ( ) posted Thu, 24 February 2005 at 8:40 AM · edited Thu, 24 February 2005 at 8:44 AM
Dell 1.9 GHz - 1 GB RAM - 59 seconds (P4) - Win XP Home
Message edited on: 02/24/2005 08:44
cheers,
dr geep ... :o]
edited 10/5/2019
geep ( ) posted Thu, 24 February 2005 at 8:58 AM
Dell 1.9 GHz - 1 GB RAM - 350 seconds (P5) - Win XP Home
cheers,
dr geep ... :o]
edited 10/5/2019
DarkSkills ( ) posted Thu, 24 February 2005 at 12:18 PM
Dell Laptop P4 3.2GHZ - 1GB RAM - 180 seconds (P5) - Win XP Pro
Stay Focused.
DarkSkills ( ) posted Thu, 24 February 2005 at 12:26 PM
Dell Laptop P4 3.2GHZ - 1GB RAM - 32 seconds (P4) - Win XP Pro
Stay Focused.
svdl ( ) posted Thu, 24 February 2005 at 2:41 PM
Athlon64 3500+ Socket 939, 4 GB Transcend DDR 333 Dual Channel, WinXP Pro, P5: 159 seconds.
My gallery   My freestuff
raz ( ) posted Thu, 24 February 2005 at 9:57 PM · edited Thu, 24 February 2005 at 9:57 PM
looks to be that P5 is slower for everbody. Still, whatever P6 brings, im sure my system will be faster than before based on the numbers here.
SVDL.... FOUR GIGS OF RAM???? WOW!!!! thats a screamer I'll bet. ;)
Dale B. "And just remember, kiddes, that '3400' is the PR rating, not the clock speed....which I =think= is still under 3 ghz".
You are correct. The actual clock speed for the 3400 is clocked at 2.2 with PC 3200 (400Mhz) memory.. But , it runs stable overclocked(tested to 3400 with the right cooling stuff). Amd has sone this for a while. I call it a "marketing ploy" The difference is it has 1 full meg of cache on the chip. lol
Message edited on: 02/24/2005 21:57
operaguy ( ) posted Thu, 24 February 2005 at 10:31 PM
Attached Link: http://www.renderosity.com/messages.ez?ForumID=12356&Form.ShowMessage=2130434
I've got a rig almost exactly like svld and get the same time....157-159 for the Poser5 test...but
S., did you see the thread where some guy with a half-gig Ram and a 3200+ is doing better than us by 12 seconds??
Attached link.
::::: Opera :::::
svdl ( ) posted Fri, 25 February 2005 at 3:47 PM
I saw it. But the image he posted is of the old P4 CPU test, not the P5, and since the P4 CPU test scene has no raytracing or dynamic hair I can believe it's faster!
operaguy ( ) posted Fri, 25 February 2005 at 3:57 PM
That's what I think, as well S., but after so many posts talking and showing image from P5 Test, i find it hard to believe he continues to report results from P4. I Think I'll ask specifically. ::::: Opera :::::
