Good...you already have it. You can do something like put a "+" or something in front of all the Inj files with it, then you can combine the Inj and Rem into one folder. For me, I put all the Uni-mesh Inj/Rem and Mat files into the face library. All pose files went into the Camera library... And Mats for clothes, hair, and Vic2/PTGirl, are in the Pose library. Everything is neat and tidy and works with no problems. Course I'm not the typical Poser user as I don't have a huge runtime (2 gigs..60% of which is textures). Good luck organizing, SWAMP
Thanks, Swamp for the excellent suggestions. I have several runtimes, but your method looks quite good. Would you mind enter a bit into details? how you can bring these files into a face library for example. (different extensions, no?)
I have tried prudent planning long enough. From now I'll be mad. (Rumi)
My pose-folder is fully packed. I allready had to put several folders into a new one or merge folders of the same kind of pose. Still too big. Can I put e.g. Victoria Injections and Removes in one folder without causing problems or having to rename single poses? Any other tipps and hints?
