Vue F.A.Q (Last Updated: 2024 Sep 20 5:40 am)
Can you tell us which building you try to access? So that we can look at it as well. If it is not grouped but one object i don't see a chance really. Only if these walls have a separate material. Then you can split the object in it's model parts by materials. If you have the walls separated you of course can simply delete them. What you can try as well is to make the wall material of the original building completely transparent. Then they are gone too. You then have to add some extra walls. Maybe that is easier.
I'm just playing with a simple building that ships with Vue5 and was wondering how could I remove say one or two of the walls and join them together to make a long hall with windows. Obviously at the moment I can pop several buildings together but when I venture inside the walls get in the way of a view down the long hall so I thought, I know, I'll remove a couple of walls! But I'm stumped now.
