Blender F.A.Q (Last Updated: 2025 Jan 28 1:01 pm)
ill do the next one on walls then i think you did pretty well here try in the next days to do some more so the keys will become second nature.You need at least 4 for a decent castle any how.:) To rotate the end of the wall go into top view num 7 key and press r key then z
for
some free stuff i made
and
for almost daily fotos
Right, I'll try that. Thanks. Um... I would like to know how to export - and yes, I've found the "Export" button, under File, but when I tried to use it I wasn't sure (and obviously got it wrong 'cos it didn't save anything) exactly HOW to export. I have hunted through the manual - all three sections - and although "Import" is mentioned, I can't find "Export" (even if I could understand it). I want to export as... "TowerA.dxf" - since I can't find any .obj options to export under. (Which is what I really wanted, but dxf will do.) I mean, WHERE do I type the name I want to export it under? And then what do I press? Please help? (and you didn't explain wht you mean't by "smoothed with simple subdivide on" - do you think you could explain that? I.e. tell me how to do it? Please? Fran (working hard)
Measure
your mind's height
by the shade it casts.
Robert Browning (Paracelsus)
Attached Link: http://newcollege.clayton.edu/itmm4404/tutorials/python_installation.htm
sorry for that knitting comment i lost my temper for a mo lol, Export is a diffrent function then save and u asked about saving. eporting as .obj is possible just install python as it uses an python script i believe.for
and
Aha, that'll be why my attempts at exporting didn't work. Oh, don't worry about the knitting, I've never managed to figure that out, so I picked up a ball of wool, looked at it, and thought... NAH! (ggg) Besides, modelling is much more exciting! Hey, did yu see, did yu see? I did the causeway all by myself! (proud expression) (did it wrong, but hey, don't knock it, could come in useful) I'm one of the "never-throw-anything-away" school of thought. I'm off to install python then. Fran
Measure
your mind's height
yes the walk way is good just rotate the outer edge as i said before 7 then r ,z
for
and
Yup, will do, thanks. I've installed python but there's still no option to export as .obj I can export as a dxf, but I can't get that into Wings. Is there any way to assign different materials to different faces in Blender? Fran
Measure
your mind's height
Measure
your mind's height
Oh VERY gooOOOD! Did it take you long to think of that one??? (Thanks for the tips for assigning materials/textures - will use that.) F
Measure
your mind's height
I think that's worse! (gg) Fran
Measure
your mind's height
Measure your mind's height
Fran's Freestuff
http://www.FranOnTheEdge.com
