Thu, Nov 14, 9:19 PM CST
Poser - OFFICIAL F.A.Q (Last Updated: 2024 Nov 14 4:48 pm)
Subject: Transparency Maps - adding text on Poser 5
aniela ( ) posted Tue, 01 March 2005 at 6:30 AM ยท edited Thu, 14 November 2024 at 9:10 PM
I want add a text on my picture. I found a tutorial explaining how do it but on Poser 4 that seems have the option transparent maps on dialog material. Poser 5 dont have this option on material room.
I made my lettering on Photoshop, black and white, added a square prop on my scenic and I cannot find how it works.
It should be great if someone explain to me or give me a URL for some good tutorial.
Thank you very much again,
aniela
geep ( ) posted Tue, 01 March 2005 at 6:51 AM
Hi aniela, You might find some help in [ THIS TUTORIAL.](http://www.renderosity.com/messages.ez?ForumID=12356&Form.ShowMessage=1663563) <---CLICK LINK Load your transmap as an external texture map (see Page 5) and then plug it into the transparency input (see Page 9). cheers, dr geep ;=]
cheers,
dr geep ... :o]
edited 10/5/2019
aniela ( ) posted Tue, 01 March 2005 at 7:17 AM
Hi Doc.:-)
I saw this tutorial before my post and even played with transparency settings. I get 2 extremes: or I dont see nothing when rendering my pic (everything is transparent) or my lettering (white) have the same transparency as his background (black). I couldnt find how make only black transparent. I checked out again this tutorial to see what I missed but no clue.. aniela
randym77 ( ) posted Tue, 01 March 2005 at 7:54 AM
Post a screen shot of your material room settings.
geep ( ) posted Tue, 01 March 2005 at 8:47 AM
............. ya needs ta do what randym77 sez. ;=]
cheers,
dr geep ... :o]
edited 10/5/2019
aniela ( ) posted Tue, 01 March 2005 at 8:57 AM
Finally I got a creen shot (next time I will post one question at time..eheh) Sorry, I was getting info to help PhilC help me.:-) Well, as I said early I tried several combinations, I am sending only one.. regards, aniela
randym77 ( ) posted Tue, 01 March 2005 at 9:07 AM
Try setting Transparency_Falloff to 0.
randym77 ( ) posted Tue, 01 March 2005 at 9:10 AM
Oh, and you should attach the transparency map to Transparency.
aniela ( ) posted Tue, 01 March 2005 at 10:04 AM
yesssssssssssssssss.:-))
It works!! The only thing I didnt try was attach image to transparency.:-)
I wanted send to you but now I am playing with effects I can apply on the text.:-)
Thank you very much for your care!
And thank you to you too Doc (I did already at render thread.:-)
regards,
aniela
AntoniaTiger ( ) posted Tue, 01 March 2005 at 11:53 AM
You set the colour of the text in Diffuse_Color If you want to get a bit of reflection from the lettering, set the Specular_Color as usual. To prevent reflections from the transparent part of the object (you might want them for glass), plug the transparency map into both Transparency and Specular_Color It's that last which can sometimes catch people out with Poser 5.
aniela ( ) posted Tue, 01 March 2005 at 12:15 PM
Aww, thank you very much for your tip. In fact I am trying lot of options here to find good visual effects on lettering.
BTW, I learned only today I can plug using mouse (hitting and dragging) and now I know how plug more than 1 node to another. Living and learning. Learning and living.:-) I think I am discovering Nodes's World.
regards,
aniela
