Poser - OFFICIAL F.A.Q (Last Updated: 2024 Oct 22 12:41 am)
Are the verts of the bad polys the same on both sides (can't tell from the picture) or is it an issue with the UV map (I wonder?). If it is the verts... You could bring the head into Wings3d (free) and move the verts into the correct position - then save the object, load as morph and your done. (I've left out detailed steps becuase it sound like you know the out>poser, in
WHOA! That's a Beaut. What a Honker. ;)
Thanks for the replies. Yes, it's just one side of the nose that has an error.
Off the top of my head, these are suspected trouble makers:
NoseSmall
HdJapanese
HdAsian
HdAsian2
I need to run back through each and every morph in the head pack to find, and list them all. I'll need a bit of time to do that.
Perhaps because I have the MAC version of the M3 Head morphs is the reason why the morphs are wack?
Sadly, I can't run Wings3D on my Mac. I'm using OS9. :(
Is it easy to select individual vertices to fix the positioning?
bB
Message edited on: 03/01/2005 22:27
Luke and Laura have weird going ons in some of their morphs too. Nothing super noticable but there none the less.
โ ฮฉ Poser eZine
ฮฉโ
โ ฮฉ Poser Free Stuff
ฮฉโ
โ ฮฉ My Homepage ฮฉโ
www.3rddimensiongraphics.net
ย
I'm going to have to give this some thought.
It's actually pulling holes in the mesh (as opposed to just moving the verts around).
Now why would it do that???
It's got to be a problem with the morph. (Guessing)
Your idea of halving the head and restitching it is interesting but I think it would mess with the vert order and cause terrible problems ( I believe Poser is very finicky about vert order - but I may be mistaken.)
Hmm... I haven't messed with Luke and Laura that much to notice. I use M3 99% of the time, and I do alot of close-ups too, so this problem just drives me crazy. Sure you can retouch your renders, but there's no way I'd rotoscope an animation just to fix pologon nose zits. I'm sure other people would feel the same. Here's the update on the Great Morph Error Hunt: Good news, all ear morphs are fine. Bad news, I found 5 more errors in the nose morph section, which brings the current total to 14 morph errors, that's 14.000x the distortion if all the morph errors at set at one. The nose errors are: NoseRidgeOut NoseBridgeOut NoseBridgeThin NoseBridgeUp NoseSlope To make it more obvious, I'm going to do a gif animation that show the movement of vertices in places that shouldn't be moving, (the right side of nose does not move, but the left side does). You can see the animation of the 5 nose morph errors listed above here: In this quick gif animation, I only used the 5 nose morphs. You can view the gif animation here 712k: http://home.earthlink.net/~bastblack/images/M3nosemorpherrors.gif Also, see the thread I started on DAZforums about this. Porthos has posted a picture of one of her characters that has the dreaded nose zit problem too. bB
Jeffg3, Is that how it looks in Poser 5? It looks worse! Eek! Thank you so much for taking the time to look into this. I know there's a program that mirrors morphs, so morph creators can save time. However, I know very little about it. It may just be for magnets. That's where I got the idea of "mirroring" the morph from the right side to the left. If this program can take a morph from one side of the face and flip it to the other. All M3's wonky head morphs can fixed very. very quickly! =) Wouldn't that be nice? =) bB
More news from The Great Nose Zit Morph Hunt: 21 more morph errors in the exact same trouble spots on the left side of the nose. From the Features Section: HairlineSmall TemplesIn BrowAngleUp BrowHeavy BrowSmall BrowSoft BrowsGone CheekBones CheekDimples CheekSink CheekBoneSmall JawFull JawSmall JawYoung MandibleSmall ChinCleft ChinProtude ChinSmall ChinStrong CheekCreaseR CheekCreaseL btw, I have made screen captures of every single morph error I've found, but for the sake of bandwidth, I won't load them on the forum. If anyone want to see all the screen captures for each morph error, please let me know. Thanks. So far the total number of errors are 35. So if those 35 morphs are set at 1.000 that would be like one bad morph being set to 35.000. That's the distortion amplified 35x! =0 Here are the confirmed errors so far: Eye: EyeCornerDown EyeCornerBack EyeCornerIn LacriminalSize LashesLong LashesUpFull LashesLoFull LashesUpStraight LashesLoStraight NOSE: NoseRidgeOut NoseBridgeOut NoseBridgeThin NoseBridgeUp NoseSlope Features: HairlineSmall TemplesIn BrowAngleUp BrowHeavy BrowSmall BrowSoft BrowsGone CheekBones CheekDimples CheekSink CheekBoneSmall JawFull JawSmall JawYoung MandibleSmall ChinCleft ChinProtude ChinSmall ChinStrong CheekCreaseR CheekCreaseL I'll continue to comb though the morphs tomorrow. Night all. bB
For some reason - my last post was deleted from this thread. Not happy about that! Anyhow, the fix to this is that someone needs to do the following. For each of the troublesome morphs: 1. Dial the morph to "1.0". Export the resulting head geometry as a morph target out of Poser. 2. Import this into your favourite modelling/morphing application (Best one would be ZBrush - see next step) 3. Correct the erronous vertices. Best way to do this would be in Zbrush as all you need to do is mask off all but the erronous areas and run the "Smart ReSym" tool, which will try to get the correct vertex positions from the other side of M3's head (i.e. will try to mirror in X). 4. Export the corrected geometry and re-import it into Poser to replace the old morph data. Boom. That's it. Of course, this going to be very time-consuming (there are a literal tonne of morphs to fix up as evidenced above). Still the question should be (given how easy it is to fix, as it's a known fact DAZ uses ZBrush), why hasn't it been done before now? The problem has existed for quite some time (as evidenced from the fact that it keeps popping up in this forum), and I would have thought - should have been fixed long ago. EK
EK,
Thanks for the reply. I don't what happened with your first post.
Wow, ZBrush sounds like a really great program. I have it on my wishlist.
I would have thought it would have been fixed by now too! I've know about it since Nov 26th, 2003!!!! I have to wonder if this were V3, would the errors have been fixed before now? sigh
Anyhoo, here is my final list of all the errors:
66 Head Morph Errors on the Left Side of Nose in the 8 polygon "zit" zone
(All errors are availible in screen capture form. Please email me for samples.)
NOSE = 4
NoseBridgeOut
NoseBridgeThin
NoseBridgeUp
NoseSlope
EXPRESSIONS = 16
BrowArchR
BrowArchL
RBrowUp
LBrowUp
BrowDownR
BrowDownL (NOTE: This is a mirror morph error on the Right side of nose and not Left!)
BrowFrownR
BrowFrownL (NOTE: This is a mirror morph error on the Right side of nose and not Left!)
BrowWorryR
BrowWorryL (NOTE: This is a mirror morph error on the Right side of nose and not Left!
Blink Left
Blink Right
EyeWince1L
EyeWince1R
EyeWince2L
EyeWince2R
EYE = 9
EyeCornerDown
EyeCornerBack
EyeCornerIn
LacriminalSize
LashesLong
LashesUpFull
LashesLoFull
LashesUpStraight
LashesLoStraight
FEATURES = 21
HairlineSmall
TemplesIn
BrowAngleUp
BrowHeavy
BrowSmall
BrowSoft
BrowsGone
CheekBones
CheekDimples
CheekSink
CheekBoneSmall
JawFull
JawSmall
JawYoung
MandibleSmall
ChinCleft
ChinProtude
ChinSmall
ChinStrong
CheekCreaseR
CheekCreaseL
MOUTH = 16
Philtrum
Philtrum2
PhiltrumIn
LipsStylized
LipsUpCurves
LipUpFull
LipUpRound
LipUpSides
LipUpThin
LipLoLarge
LipLoNarrow
LipLowFull
LipLowOut
LipLowThin
MouthNarrow
MthCrnrSml
EAR
-No Errors Found-
HEAD
-No Errors Found-
TEETH-GUMS
-No Errors Found-
Okay, now I have face poses that will turn on all bad morphs at the following settings:
.25
.5
.75
1.0
....and MORE IMPORTANTLY a zero pose of all bad morphs. This will be really handy for Character Developers. Just apply the face pose to turn off all morphs with errors in the dreaded 8-polygon-nose-"zit"-zone. All other dial settings will not be effected.
You can download the file here:
http://home.earthlink.net/~bastblack/images/M3NoseMorphErrors.zip
Let me know if this works for you. I'm going to start using the zero pose myself to fix all my character faces. At least that's something. I'm ready to email Daz Tech support now. I think it's only a matter of time until the errors get fixed or there'll be some good work-arounds for us.
Thanks for your feedback gang. =)
bB
Message edited on: 03/02/2005 20:59
Hi Eternl_Knight, Your previous post hasn't been deleted, as it never appeared in the thread at all. (We keep a record of deletions.) What probably happened was server timeout- if it takes too long for you to make your post, while the page is sitting idle, you can get thrown out of the thread and back to the main forums page without your post being actually made. (This usually happens to me when I'm halfway through replying and then my little boy calls me. Come back, press post, no reply!) Sorry for the confusion and inconvenience. Karen Poser Mod
"you are terrifying
and strange and beautiful
something not everyone knows how to love." - Warsan
Shire
