Have you had success importing other OBP files? It may be worth trying another. If that works, then maybe there is something wrong with the OBP. If it fails, then maybe your version of Bryce isn't compatible? Is this Chohole's Bridge? I've tried it and imported it without a problem.
Phillip Drawbridge
Website
Facebook
artbyphil when importing obp files into bryce 5 don't try and do it with file/import object it won't work. to import an obp file you need to go into create/user library, click on import and then highlight the obp file you want to import into the library. Only files you use file/import object are ones like .obj, .3ds, .DXF or anyother listed in there. You can only import them on to your work screen then you have to save them from there.
I have opinions of my own -- strong
opinions -- but I don't always agree with them.
Hi! New to bryce and i downloaded the Rustic bridge object and when i went to import it, its not showing up in the folder O.o Its in OBP file, i put it in my ''presets, objects, installed'' folder but it doesnt show..anything i've downloaded from the free section wont show..Any help would be much appreciated as to where to put them and how to get them to import.. Thanks in advance.
