Oh and BTW, the image I am working on at the moment has to date 24 poser figs in it, and more to come. I have to admit I am rendering in layers with object masks though.
The greatest part of wisdom is learning to develop the ineffable genius of extracting the "neither here nor there" out of any situation...."
Moonflower to answer your simple question which somehow someone turned into a full story on an image.
yes it is the only plugin for importing poster files into bryce. you can do it with out the plugin if you know what you are doing.
@danamo if you care to read the statement that chohole made before hand, the one about rendering in layers. Moonflower replied to that one with the comment "That way is a pain in the A*S"
some advice for you danamo, before jumping down someones throat about something they posted. Read everything first.
Message edited on: 03/05/2005 22:00
I have opinions of my own -- strong
opinions -- but I don't always agree with them.
Just to the north of South Dakota. :^)
Monteplier? not Bismark?..dang..I fergit..;)
Well, it depends on the memory, I guess..last 2 pictures I did have an average of 10 characters, but it was touch and go towards the end..;)
The short answer is that in order to have the characters to export, you need Poser, yes (or Daz |Studio, which is free from Daz3d.com). You can use the .obj export in Poser to export with. Trick is getting the textures to go. You can do them manually (search down each texture directory, and point to the file), or use a program called 'Grouper', which, I think, is still available in Freestuff (maybe also at Morphography, I haven't checked lately). And if you get Daz |Studio, there's also a converter that gets loaded into Bryce that they offer. go to it..
is the Daz plugin still the only way to import from po ser to Bryce?
