Blue, Mike does have a pubic prop but this problem isn't related to it....As far as the pubic prop goes I am just wondering if anyone has done anything with it that looks decent...Most attemps I have seen to use it look terribly unconvincing...I am still hoping that someone will come across this thread with an answer....
Ghost,Thanks for the response but I am still left up in the air about this... There is no extreme morph applied to the hip or to the abdomen......What the image above doesn't show is the fact that the same type of broken line appears also where the hips meet the legs or buttocks...So the problem seems to be with every point that the hip intersects with another part of the body...This file has been saved and each time I load it the hips are showing up as being invisible...I have to hit the genital off on bit to even get the hip area to appear...And what you see above is the result....I do not have Michael set as my default figure when opening Poser but I get the same result when I click him as a new figure.... The missing hips....You guys are old pro's at this as opposed to me..Someone has to have a clue as to what is going on...
