Wed, Jan 8, 1:01 PM CST
Subject: michael hip problem
kennect ( ) posted Sun, 14 January 2001 at 10:23 AM ยท edited Tue, 07 January 2025 at 4:58 PM
I know this has been addressed before but I can't find anything archived that really solves the problem for me...Hopefully the attached image is somwhat obvious as to what my problem is...After dropping Mike into the document window, he shows up with those mysterious transparent hips...A simple click of genitals off/on takes care of the problem but leaves me with this broken seam look...Any advice on the matter would greatly be appreciated....
BlueRain ( ) posted Sun, 14 January 2001 at 10:30 AM
Someone said once that He has trans map pubic hair, Could the stange lines be that pubic hair patch?
kennect ( ) posted Sun, 14 January 2001 at 3:20 PM
Blue, Mike does have a pubic prop but this problem isn't related to it....As far as the pubic prop goes I am just wondering if anyone has done anything with it that looks decent...Most attemps I have seen to use it look terribly unconvincing...I am still hoping that someone will come across this thread with an answer....
Ghostofmacbeth ( ) posted Sun, 14 January 2001 at 5:42 PM
I normlly only see that when one of the parts has the heavy morph applied and the other one doen't .. It could be the tone option does the same thing .. check that first ...
kennect ( ) posted Sun, 14 January 2001 at 5:55 PM
Ghost,Thanks for the response but I am still left up in the air about this... There is no extreme morph applied to the hip or to the abdomen......What the image above doesn't show is the fact that the same type of broken line appears also where the hips meet the legs or buttocks...So the problem seems to be with every point that the hip intersects with another part of the body...This file has been saved and each time I load it the hips are showing up as being invisible...I have to hit the genital off on bit to even get the hip area to appear...And what you see above is the result....I do not have Michael set as my default figure when opening Poser but I get the same result when I click him as a new figure.... The missing hips....You guys are old pro's at this as opposed to me..Someone has to have a clue as to what is going on...
Ghostofmacbeth ( ) posted Mon, 15 January 2001 at 12:17 AM
I know on the mac there was an update for the hip . I am not sure if you are on a Mac or a PC but that could be it as well
bloodsong ( ) posted Mon, 15 January 2001 at 1:53 PM
heyas; yeah, i had that happen when i forgot to get the michael update. the update fixes that.
