I have to ask why? It is cool, btw, but why?
Come visit us at RenderGods.
Ignore the shooty dog thing.
Thanks AS! But I don't think I'll bother. Sphere #875 is 0.021bu out of line...........
"it's 2,000 spheres, so give it a minute to load up." Then give it a minute (or two) whenever you want to select one of the families, and another minute (or three) if you want to do anything to them :)
Its not so bad once the scene is loaded up, BUT...I STRONGLY suggest taking your wireframe resolution down to 8 or 16. AgentSmith
Contact Me | Gallery |
Freestuff | IMDB
Credits | Personal
Site
"I want to be what I was
when I wanted to be what I am now"
Lol....every sphere is absolutely perfectly spaced....;o) (through the miracle of multi-rep) AS
Freestuff | IMDB
Credits | Personal
Site
Attached Link: community page
Why - I just kept seeing these in high render scenes, decided to build one, then I ended up using it for the community page graphic. No reason why, truly. I was just screwing around. AS
Freestuff | IMDB
Credits | Personal
Site
Pretty simple, everything is just spaced 20 units apart. With multi-rep, you could create this thing in a matter of minutes. AS
Freestuff | IMDB
Credits | Personal
Site
Size everything up, put your camera inside, it could look like an Escher.
You're welcome. ;o)
The rods can be made hollow easy;
*Select all cylinders (using the family color)
*In Attributes, make them all positive. Apply.
*Then, ctrl+d to duplicate them.
*The duplicates will automatically be selected, best give them their own family color.
*Select the duplicates attributes and make them negative & make them smaller than what they currently are. (maybe take the XYZ down by 2 units each, for example). Apply.
NOTE;
How to simulate a Rod (or even a sphere) as hollow without doing all this booleaning??
Easy...just give whatever glass material you are using a refraction of (around) 76. (and it renders faster than booleaning)
;o)
AS
Freestuff | IMDB
Credits | Personal
Site
Attached Link: Download
Hey, here's that sphere "rack" I told you all I'd give up.It's no big deal, just a simple model, but its rather big.....it's 2,000 spheres, so give it a minute to load up.
The deal is, the spheres are booleaned (1,000 spheres inside of 1,000 spheres). This way if I wanted to make the spheres glass with a hollowed out interior, I easily could.
As the scene file is...ALL the spheres are neutral.
Via families, you can select the Inner spheres, the Outer Spheres, and Rods. You can then select and make all the inner spheres negative, the outer ones positive, or just delete the inner spheres, whatever you want. Using the family's also makes it easier to apply materials.
*Use this for absolutely whatever you want, commercial or non-commercial, re-distribute in any way you freaking want. I relinquish any and all copyright to this scene file and all its contents to anyone/everyone.
Thanks.
AgentSmith
