Tue, Jan 28, 5:32 PM CST
Poser - OFFICIAL F.A.Q (Last Updated: 2025 Jan 28 6:42 am)
Subject: POSER 4 UPGRADE TO POSER 6
L13RAF ( ) posted Sun, 13 March 2005 at 5:42 AM · edited Tue, 28 January 2025 at 5:30 PM
Greetings from England,
Has anybody tried to purchase the Poser 4 to Poser 6 upgrade and been successful.
I have a legitimate Poser 4 serial number that is registered with Curious Labs but when I try to order the upgrade I am constantly told that my serial number is invalid and therefore not acceptable.
Does this indicate that you cannot upgrade directly from 4 to 6.
Any help would be gratefully received.
L13RAF
roxcat ( ) posted Sun, 13 March 2005 at 5:46 AM
I'm from Sweden and I managed to upgrade to Poser 6 from Poser 4 without any problems. If you're sure that you're typing the serial correct (check the P6 FAQ on their site) I suggest you contact Curious Labs for help.
L13RAF ( ) posted Sun, 13 March 2005 at 6:56 AM
Thanks for your reply and pleased to read that you upgraded from 6 to 4 without problems. I have written a number of e-mails to Curious Labs who keep telling me to check that my serial number has been entered correctly and not being a stupid person I have entered it the was it is written on their information and still have not answered follow up e-mails informing them of that. I refuse to pay for the full version when I meet the critera to upgrade and maybe one day I will get an answer from them and get my upgrade from 4 to 6 Best wishes and thanks, L13RAF
RHaseltine ( ) posted Sun, 13 March 2005 at 8:00 AM
Accepted my 4 to 6 upgrade order too, and I'm in the UK like you.
geep ( ) posted Sun, 13 March 2005 at 8:10 AM
?????????????????????????????????? s/n's DO NOT use the letter "O" if you see "0" in the s/n, it is the number "0" (zero). Also, "dashes" (-) must be entered and the s/n DOES NOT HAVE any SPACES in it. Just a couple of thoughts. cheers, dr geep ;=]
cheers,
dr geep ... :o]
edited 10/5/2019
L13RAF ( ) posted Sun, 13 March 2005 at 8:31 AM
My serial number which starts XF41CUZ is confirmed by Curious Labs when registered with them and when I have reloaded Poser 4 software it accepts the serial number without any problem. So where does the answer lie with this problem ???????? L13RAF
Ethesis ( ) posted Sun, 13 March 2005 at 8:42 AM
If someone else has upgraded with your serial number, it blocks you out.
L13RAF ( ) posted Sun, 13 March 2005 at 8:56 AM
I think the cause may have come to light in the because I used my 4 serial number to upgrade to 5 it has blocked out my 4 serial number. I did explain to Curious Labs that I lost my 5 discs and documentation in a fire at my home so reverted back to using 4. I have requested them to re load my 4 serial number in to their system so that I can then upgrade. No doubt they will say 'No' and tell me to purchase a relacement version of 5 :-) L13RAF
Ethesis ( ) posted Sun, 13 March 2005 at 12:57 PM
Ah, what they may be able to do is confirm your P5 serial number for you (I'm assuming you registered?) and you can then use that.
L13RAF ( ) posted Sun, 13 March 2005 at 3:06 PM
Hi, Thanks for your reply. Yes they have confirmed my 5 serial number but that only allows me to upgrade from 5 to 6. 5 is no longer installed on my computer after the fire so I need them to re-allocate my 4 serial number to complete the upgrade from 4 to 6 and not 5 to 6. Many thanks, L13RAF
agape ( ) posted Sun, 13 March 2005 at 4:19 PM
Hi L13RAF!
In conversing with CL about DAZ character compatibility, here is what they said about upgrades to P6:
"The Poser 6 upgrade installs a whole new application- it doesn't change your existing Poser 5 application at all. Like Poser 5, Poser 6 can use multiple Runtime folders, so you can link your Poser 4, 5, etc. Runtimes into your Poser 6 Library palette and use that content without altering anything in those applications. This also allows you to remove or reinstall Poser 6 without affecting any other installed versions of Poser, or their Runtime folders."
This tells me that I can run P4,5 and six at the same time. By ordering P6 upgrade, you are really getting a discount for being a Poser user. It doesn't change P4 into P6. Hope this helps!
Ethesis ( ) posted Sun, 13 March 2005 at 6:49 PM
So, you don't need P5 installed to install P6 or to install the "upgrade."
InfoCentral ( ) posted Mon, 14 March 2005 at 12:24 AM
Since the upgrade is for users of P4 through P5, I would assume that it would look for either version before upgrading. That meaning if you had either 4 or 5 installed it would be OK. In the past, you didn't need either as the upgrade was just a discount at the time of ordering. The software was the same as the one sold in the store. There was never a seperate upgrade version and full version software. I would assume that is still the case. I still will need P4 Pro installed since this is the last version with a Lightwave plug-in.
RHaseltine ( ) posted Mon, 14 March 2005 at 7:55 AM
They ought to be able to replace at least the Poser 5 CD, in case the upgrades are version specific, for a token charge (especially if you have the insurance etc. paperwork from the fire).
