Mon, Jan 13, 10:38 PM CST
Subject: Made prop in bryce... can't export to Poser... Why?
DigitalDreamsDS ( ) posted Tue, 15 March 2005 at 9:44 AM ยท edited Fri, 27 December 2024 at 2:23 AM
I made a prop in Bryce5 useing the cube. When I go to the menu to export the object I'm not able to select that option. How do I make it so that I can export things like the cube and sphere?? Thanks all!!
Claymor ( ) posted Tue, 15 March 2005 at 9:49 AM
bryce can only export terrains, lattices, and things you first import. It doesn't export primatives.
draculaz ( ) posted Tue, 15 March 2005 at 10:56 AM
claymor is wise
Aldaron ( ) posted Tue, 15 March 2005 at 12:02 PM
We need Clay's post in big flashing letter's in the header of the forum :) It also doesn't export metaballs or trees before anyone asks :)
pakled ( ) posted Tue, 15 March 2005 at 1:15 PM
Attached Link: http://www.wings3d.com
if you use this, you can import into Bryce or Poser.. Wings local 509..;) Also does uvmapping on the models you create..
shadow_dancer ( ) posted Fri, 13 May 2005 at 5:11 PM
bryce 5.5 wont even export imported objs back out
Aldaron ( ) posted Fri, 13 May 2005 at 6:30 PM
I've had no problem shadow_dancer. Imported an .obj file and then exported as a .dxf using "e"/ctrl-d
shadow_dancer ( ) posted Fri, 13 May 2005 at 8:04 PM
tried that i got a unknow error :( maybe it was because i modified the obj but i used to modify them in bryce and export out b4
Aldaron ( ) posted Sat, 14 May 2005 at 12:09 AM
modified how?
shadow_dancer ( ) posted Sat, 14 May 2005 at 12:23 AM
modifiued obj by deleting phantom horns lynes doe and fawn for example..... i would model something in c4d then put it in bryce and check it for oddities out of place vertices prts fix it and export it back out
