Attached Link: http://www.wings3d.com
if you use this, you can import into Bryce or Poser.. Wings local 509..;) Also does uvmapping on the models you create..I wish I'd said that.. The Staircase Wit
I made a prop in Bryce5 useing the cube. When I go to the menu to export the object I'm not able to select that option. How do I make it so that I can export things like the cube and sphere?? Thanks all!!
