Wed, Dec 25, 1:13 AM CST
Subject: Tree Bending question for Vue Xfrog & Cinema4D
imagist ( ) posted Thu, 17 March 2005 at 5:57 PM ยท edited Wed, 25 December 2024 at 12:06 AM
Hi All well this is as far as have got with the bending of palms I have been using an XFrog palm but am not skilled enough to work out if it is possible to bend in this program I saved the image as a lightwave file which is the image on the left. I resorted to Cinema 4D and found a way of bending the tree trunk but in saving I lost all the textures when saving as a 3d studio model. It seems like I have solved one problem to find that I cannot get as usable file format for Vue :-(
Any help greatly received
Keith
Orio ( ) posted Thu, 17 March 2005 at 9:55 PM
In Xfrog you have various ways to bend a trunk: you can use the dedicated spline, or you can apply gravitropism to it, or you can even use an attractor (although this would be an "overkill") - not to mention deviation (for smaller/subtler changes. There is nothing to really "learn", just modify one of those things and see what happens. Export the model from Xfrog as 3DS or (if you use embedded alpha in the maps) as LWO, and you will be able to import into Vue smoothly. If you need help in the import process, please refer to my tutorials (I think they are listed here somewhere). Orio
imagist ( ) posted Fri, 18 March 2005 at 4:45 AM
Hi Orio thanks for your reply I have looked again at Xfrog and will have to sit down with the reference manual as it is not obvious how you bend the trunk on an imported model like the one I have been using. As for you tutorials I could not find anything in Renderosity tutorials This what I have when I open the Palm tree in Xfrog
Regards
Keith
imagist ( ) posted Fri, 18 March 2005 at 6:34 AM
Ha Ha I found that if you ungroup the sise it gives you more items to play with LOL still lots to learn
Looking forward to a peep at your tutorial Orio
Regards
Keith
