Sun, Jan 12, 4:31 AM CST
Subject: Hi Res Mesh Image
imagist ( ) posted Sat, 19 March 2005 at 1:10 AM ยท edited Wed, 25 December 2024 at 12:36 AM
Hi All I am intereted in hi Res bare mesh image of a model but I can't find any way to get one in Poser
DCArt ( ) posted Sat, 19 March 2005 at 1:29 AM
Display > Document Style > Wireframe.
imagist ( ) posted Sat, 19 March 2005 at 2:12 AM
Hi Denise thanks for the tip but can the image output be improved to give finer lines to the mesh or is it always a 72dpi capture of the mesh
Regards
Keith
Helgard ( ) posted Sat, 19 March 2005 at 2:18 AM
Display > Document Style > Wireframe. Then render as movie, using current display settings, but just a single frame, and you can set your size in your movie settings.
Your specialist military, sci-fi, historical and real world site.
Helgard ( ) posted Sat, 19 March 2005 at 2:25 AM
Or if you want the hard way, open model in UV Mapper and save the UV map on the largest size possible, then make a copy. Invert the copy, so that the white is black and the black is white. Apply the first image you saved as the models texture map. You apply the second one, the inverted copy, as a transparency map, and then you can render on the highest settings and get any resolution you want.
imagist ( ) posted Sat, 19 March 2005 at 2:29 AM
Thanks Helgard I shall give that a try Regards Keith
