Bryce F.A.Q (Last Updated: 2024 Oct 20 11:30 am)
Go to Image -> Image Size. Uncheck Resample Image. Enter 300 as the resolution. Voila. Mind you, the print size is going to go down, while the pixel size is going to stay the same. BUT! The resolution depends on where you print it. Maybe you need just 250 dpi or something. Ask. Drac, if you noticed, when you go to Render to disk and change the resolution, the inch dimensions fall down fourfold. So you have to enter the resolution and then inch dimensions to get what you want. Basically, what Bryce does is applying that thing from Photoshop during render. So, gd, if you want to render for print, just think of dimensions, multiply by 300 and you'll get pixel size. (frex, 20x15" times 300 equals 6000 x 4500 pixels) Then divide by four and you'll get the size of the document (1500 x 1125) needed to render at four times size onscreen. Or you can always render to disk. Er, am I making myself clear? PS ASK about resolution and dimensions at the place where you will have your images printed.
-- erlik
Digital photographers often use a technique created by digital photography guru, and Photoshop User columnist Jim DiVital to increase the size of digital photos with very little loss due to blurriness, softness and even pixelation when increased. It is claimed, Ive never increase to such sizes so I personally dont know, that a 5x7 inch photo can be enlarged to an 18x24 inch poster size with little loss.
In Photoshop go to the image menu and chose image size. Make sure resample image is turned off. In the pop-up dialog change units of measure from inches to percent. Then type in 110, this will increase the image size by 10%. Continue doing this until you get the image size you want. 10% at a clip. Supposedly, it is reported, this does a great job. Ive tried it to smaller sizes and it works for me.
Message edited on: 03/19/2005 17:24
forget dpi just ask the printer what pixel dimensions he can print, dpi is out off date teach him that.
for
some free stuff i made
and
for almost daily fotos
DPI isn't out of date, Ysvry, it's very important to the printing process and the key to good prints. Don't try to confuse GoneDigital, please. You can NOT change DPI without changing your image size, GoneDigital. DPI is just a description of how detailed your image will be for a given print size. So, an image that is 1,000x600 will print at 100 DPI on a 10x6 card, or at 200 DPI on a 5x3 card. If your image is a a standard 8.5"x11", then 300 DPI would be 2550x3300 pixels. Like the others said, it's best done with the "render to disk" function...
I believe Bryce can go up to 3000 x 4000 on screen. This is good to know if you can't leave the computer continuously running... There's still a drawback with the "render to disk" function, and that is the fact it cannot be paused and resumed. Hopefully DAZ will fix that one.
Hello all. My situation is this...all of the images that I have created in Bryce 5 are rendered at 72 dpi, I want to have some of the images printed and would of course like the best quality, I have read that I should use 300 dpi to get the best image. Ok now the question, how do I change the dpi of a bryce image into a 300 dpi image without changing the size of the image? I have Photoshop 6. All help is appreciated! Thank you.
~gonedigital
Message edited on: 03/19/2005 12:23
