Poser - OFFICIAL F.A.Q (Last Updated: 2024 Sep 09 6:38 am)
The image is at the size it was rendered at. As for the render time, I'm not sure as I wasn't timing it. Another thing to consider is the back drop - it's a little heavy on the polygons right now because I haven't optimized it yet. I'd say it took around 10-15 minutes. I have pixel samples set to 9, raytrace turned on and max texture size turned to 3000. Raytrace bounces are set to 3.
![file_206200.jpg](https://live.cdn.renderosity.com/forum/threads/2173900/file_206200.jpg)
It just takes some tweaking. I set the AO sampling size from 3 to 6 and it looks much better. This scene has one light set to IBL and AO turned on. I'm using a picture I found of the sky via google ( didn't like the included IBL AO set ) and I found that if you take the same picture and lighten it via a color_math node, and then plug the result into the diffuse node of the light that it has much better results. The character is Jessie with the WinterQueen hair. I set up a basic skin shader with the new fastscatter node.Message edited on: 03/22/2005 09:44
