Tue, Jan 14, 6:22 PM CST
Subject: WIP - Looking for critiques
mikebres ( ) posted Thu, 24 March 2005 at 9:36 PM ยท edited Wed, 13 November 2024 at 10:37 PM
A first image with Vue5. Well, the first I was willing to post, anyway. I'm not happy with the terrain in the foreground. Any ideas how to make it look better? Also, looking for suggestions for overall improvment. Thanks Mike
DVcreator ( ) posted Thu, 24 March 2005 at 10:51 PM
Textures/scale @ terrain/res thats right, content wise, no middle ground, Eagle and puma are off focused, maybe use a Golden Eagle,head and neck golden yellow to ochre, longer shadows on the background arroyos how about a foreground with a grey cast to the stone hope it helps I'd like to see it complete R
mikebres ( ) posted Thu, 24 March 2005 at 11:27 PM
Thanks. I'm not sure I know what you mean when you say they are off focused. Can you explain that? On the shadows, i'm using a single light (the sun) and that's what the program came up with. Is there another way to lengthen the shadows, other than postwork? Thanks Mike
Orio ( ) posted Fri, 25 March 2005 at 2:34 AM
Mike, in my opinion, the main problem of the image is the composition. The three subjects are all off-centre and partially cut. Also, the two fighting subjects are on the same level, and this subtracts dynamicity. And the nest is not connected visually to the action. I would start with repositioning the elements first. You may have two solutions: 1- put nest in the foreground. Puma in the background, obliquely oriented, so that it is clear that it is heading towards the nest (and the viewer). The mother eagle in the middle ground, coming from one side aggressively into the field of view. 2- put puma in the foreground, seen from the back but oblique, so taht also a part of the face is shown. The nest in the background, along an ideal line created by puma's eyes. Mother eagle coming from above, aggressively, towards the puma (and the viewer). I think that once you fix the composition problem, the other details like texturing will become less important.
mikebres ( ) posted Sat, 26 March 2005 at 5:13 PM
Thank you. I'll give these ideas a try.
