Tue, Feb 25, 6:04 PM CST
Forum Moderators: RedPhantom
Subject: Help with my first Poser scene!
MoonFlower ( ) posted Sat, 26 March 2005 at 7:03 AM ยท edited Tue, 25 February 2025 at 3:26 PM
How can i scale my character with clothes, props and everything?
AntoniaTiger ( ) posted Sat, 26 March 2005 at 8:51 AM
Attached Link: http://www.renderosity.com/messages.ez?Form.ShowMessage=1942965
Check this thread for one description of how one user does it, for the whole scene. If clothes, props, etc, are parented to the same figure, then just rescale that figure. I've a recollection of somebody saying you could use a dummy prop to scale and move a whole set of figures, setting the prop invisible for the render.
MoonFlower ( ) posted Sat, 26 March 2005 at 9:08 AM
Thanks alot. :)
lesbentley ( ) posted Sat, 26 March 2005 at 5:54 PM
One is to load a square prop, parent everything to the square. Then scale the square, everything else should scale with it. Last, from the squares Properties make it invisible. If you only need to save as a pz3 the above method is fine. Or you could download the MinFig cr2 from the Free Stuff, and parent everything to that. The advantage is that if you then resave MinFig to a figures pallet with a new name, all the figures and props parented to it will save with it, and you can load everything into your document all at once, at the right scale. Min fig its self is invisible, and at under 5 KB file size very small.
