Tue, Nov 26, 2:15 PM CST
Subject: Poser 6 - A disappointment
  • 1
  • 2
Mason ( ) posted Sat, 26 March 2005 at 2:24 PM
Actually as I use p6 more what I'm finding is I have about the same limitations I had with P5 but now have new features. In this case its worth the switch over. I have not seen any new bugs that are show stoppers. I'm just miffed older bugs weren't fixed and P6 should be more helpful at diagnostics.
maclean ( ) posted Sat, 26 March 2005 at 3:45 PM
'Ah, Mac, I thought you were still having the "highlight part" issue. I disabled that, and found poser much harder to work with, but re enabling it was a pain, because poser kept resetting it. I finally just locked the preference file, and that took care of that!' Garee, Didn't you disable it in the .ini file? That's where I did it. Change HILITE_BODY_PART 1 to HILITE_BODY_PART 0 That kills it completely. mac
Gareee ( ) posted Sat, 26 March 2005 at 4:28 PM
Yep, that's where I did it.. and selecting body arts because MUCH more of a PITA, IMHO. Problem is, when you set it BACK, it's doesn't return. For some reason, poser keep rewriting the file with it turned off again! That's whay I finally changed it, and then locked the ini file. Poser couldn't change it back to unhighlighted, and after 2 restarts, accepted that as the "normal" mode. I then unlocked the file, and it's been fine ever since. And when trying to restore it, I think I changed and restarted poser about 12 times or so, before thinking of locking the file.
randym77 ( ) posted Sat, 26 March 2005 at 5:57 PM
I don't think my experience is unusual. A lot of people can't get P5 to cancel at all. It was improved with SR4, but still isn't perfect. (However, I will definitely try using ESC instead next time!)
My specs: Pentium 2.8, 1.5 Gb RAM, XP Home. Poser is on a 120 Gb hard drive that's more than half empty, my runtimes are on a 265 Gb hard drive that's about half empty.
The "Room of Mixtures" images in my gallery locked up Poser when I tried to cancel. They do use very high-res textures.
The infamous P5 memory leak is also a problem. I suspect that if I just opened the Poser file, started a render, then cancelled, it would probably cancel. But work on the image a couple of hours, try several test renders, then bail out on the final render because I forgot to uncheck "smooth polygons"...it would likely lock up.
maclean ( ) posted Sat, 26 March 2005 at 8:21 PM
'For some reason, poser keep rewriting the file with it turned off again' How weird, garee. I've edited the .ini umpteeen times in P4 and P5 and never had a problem. It just runs it. Oh well, poser is always full of surprises. Randym, I never use the cancel button - always Esc. And it always works. Mind you, I never use the mouse if there's an alternative, which is why I dislike poser's interface so much. LOL. mac
byAnton ( ) posted Sun, 24 April 2005 at 5:19 PM
Attached Link: Hanging on "Adding objects"
See this thread.
-Anton, creator of Apollo Maximus
Over 100,000 Downloads....
byAnton ( ) posted Sun, 24 April 2005 at 5:20 PM
See this thread.
randym77 ( ) posted Sun, 24 April 2005 at 5:44 PM
FWIW...I've tried using ESC instead of cancel. Didn't make a whit of difference.
  • 1
  • 2
