Hello Well i normaly use superior to post images on here as its not at all grainey but that depends if you using soft shadows or not but ultra is good. I have spent many an hour testing render settings,i did a render once that i made it render at about 20 or 25 sub rays per pixel..o that came out nice but took a long time to render,not much help i know haha but you never know Tattso
ah :) experimenting with it now, will see hwo it goes!
"I'd rather be a
Fool who believes in Dragons, Than a King who believes in
Nothing!" www.silverblades-suitcase.com
Free tutorials, Vue & Bryce materials, Bryce Skies, models,
D&D items, stories.
Tutorials on Poser imports
to Vue/Bryce, Postwork, Vue rendering/lighting, etc etc!
You might try the user settings as well, as I believe ultra doesn't use the most anti-aliasing that is possible, and that is where the grain is coming from. As a general guideline I almost never use the preset qualities anymore as you can shave render time and get the same quality by experimenting with the user settings more.
well with infinite, a test at SUPERIOR removed the grainyness :)
"I'd rather be a
D&D items, stories.
In my renders, graininess was often caused by using raytraced soft shadows. Even Ultra quality (4.5 Pro) didn't fix the graininess. But when I increased the quality boost setting to maximum in the light/shadow properties the graininess disappeared, even at Final or Broadcast settings. Rendering at larger sizes and then reducing image size using Photoshop or PSP also works pretty well. I often combine these two techniques. Works for me.
Attached Link: http://www.renderosity.com/viewed.ez?galleryid=862107
This is the first image where I used both tricks. Rendered at 3200x2400 in Vue 4.5 Pro, user settings (no motion blur since it's a still, quality boost in the render settings dialog pushed up to 100%). Resized in Photoshop to 1600x1200 px using bicubic resampling. There are about 20 point lights with soft shadows in the scene. All shadows have their quality boost setting at maximum. Render time about 4 hours.The pen is mightier than the sword. But if you literally want to have some impact, use a typewriter
note, and others have commented elshewhere, Vue renders are often way too grainy.
How can this be removed?
is it a quality setting in renders? :)
slaps self, cheked tutorials...silly me! :) will try rendering in Ultra mode to begin with, test from there
Message edited on: 03/26/2005 15:49
