Sun, Nov 24, 12:20 PM CST
Subject: New to Poser, need advice
JGC ( ) posted Sun, 21 January 2001 at 7:44 PM ยท edited Fri, 26 July 2024 at 7:19 AM
I made a character using the long blond curls that come in Poser. I then tried to color them black, but no matter how I change the material settings for the hair, I can't get rid of the yellow. Any advice?
Bongo ( ) posted Sun, 21 January 2001 at 7:51 PM
lighting
JGC ( ) posted Sun, 21 January 2001 at 8:00 PM
There are no yellow lights in the scene. They are all white.
melanie ( ) posted Sun, 21 January 2001 at 8:10 PM
Check the highlight color in the materials window. You would probably want a white highlight or a pale blue. Melanie
JGC ( ) posted Sun, 21 January 2001 at 8:17 PM
I tried it already. FIrst I had white for a highlight, then I just tried to eliminate the problem by making black the highlight, but that damned yello just won't go away! Argh!
Bongo ( ) posted Sun, 21 January 2001 at 8:47 PM
texture map?
JGC ( ) posted Sun, 21 January 2001 at 9:06 PM
I thought of that, but I haven't tried it because creating textures is still rather new to me. Know of any tutorials that could walk me thru it?
Bongo ( ) posted Sun, 21 January 2001 at 9:16 PM
I meant are you using a texture map - its colors can alter your render. Use a paint program to view it/ change it. Make a backup first, then go for it. Only what's within the lines will show up.
JGC ( ) posted Sun, 21 January 2001 at 9:21 PM
Ah. No, not using one, and the materials menu says there is none associated with it. If it helps solve the problem, here is more info. When I change the highlight color, there IS a change--the hair beneath the curls changes, while the curls all keep the yellow highlight. So the pic above is with a black highlight. It turns the majority of the hair and the "roots" black without affecting the curls. Sigh I'm about to give up on this one.
The 4th Party ( ) posted Sun, 21 January 2001 at 9:27 PM
make sure you are changing the colors on all the parts on the materials menu (hair/default/preveiw) 4
JGC ( ) posted Sun, 21 January 2001 at 9:32 PM
THAT DID IT, 4! Thanks for everyone's help.
JGC ( ) posted Sun, 21 January 2001 at 9:58 PM
I chose a dark grey highlight instead of white or blue. The white reflected too much and looked like pure plastic, and the blue was too dark for my taste. I decided to use a true greyscale highlight so it (the white) will reflect the lights around it more accurately and not make it look so plastic. Thanks again for everyone's input.
