Tue, Jan 21, 9:33 PM CST
Poser - OFFICIAL F.A.Q (Last Updated: 2025 Jan 21 4:30 pm)
Subject: Need a little help...
Raven_Song ( ) posted Tue, 29 March 2005 at 5:15 PM · edited Sat, 18 January 2025 at 5:18 PM
Hello. I am having some problems with the Xtreme Close Up texture pack for V3. I know that it is not sold here, but I can't seem to get much help from Daz3d, so I thought that someone here might know what to do. I am having problems applying the transparency map to the figure. Therefore, I cannot get eyebrows to appear or pubic hair, or anything else that uses that map. I checked and it is in the tecture folder, so I was wondering if I was doing something wrong, or out of order. I was also wondering if the transparency even works in poser, or if it only works in one of Daz's programs or something. Thanks in advance. My steps are: Create the figure. Apply the textures to her body. Then turn transparecny on. (But nothing changes, no eyebrows or anything.)
JenX ( ) posted Tue, 29 March 2005 at 7:11 PM
When a transparency map is applied, you won't see the part (eyebrows, eyelashes, pubic hair, etc) until the image is rendered. At least, that's how it works in P5. HTH!
Raven_Song ( ) posted Tue, 29 March 2005 at 8:59 PM
Thanks for the reply. I knew that it would not show in the window, but even when I render it, the stuff still does not show up. That is why I think that I am doing something wrong. Or that I am doing something out of order. I really can't figure it out! Is there a process or something? Does the trans map have to go on before the skin textures? Or does something else have to be done, some kind of option set somewhere? I've played with it, but I can't come up with anything. Any other suggestions? :) Thanks.
JenX ( ) posted Tue, 29 March 2005 at 9:02 PM
which version of Poser are you using? And, is there a chance we could get a screenshot of the problem? It might help us help you a bit better. :D
tastiger ( ) posted Tue, 29 March 2005 at 11:17 PM
The problem with the pubic hair may be that you haven't injected the hip morphs to V3. The area that the transmap applies to isn't on V3 until you inject the hip morphs
The supreme irony of life is that hardly anyone gets out of it alive.
Robert A. Heinlein
11th Gen Intel(R) Core(TM) i9-11900K @ 3.50GHz   3.50 GHz
64.0 GB (63.9 GB usable)
Geforce RTX 3060 12 GB
Windows 11 Pro
Fugazi1968 ( ) posted Tue, 29 March 2005 at 11:40 PM
I've never had to turn transparecy on when using xcu. When you have v3 loaded into your scene go to the xcu library and apply the default option (right at the top of the list).
This will set all the body textures to No Freckles and set the tranparencies.
If you are still having trouble, go to the materials room and make sure your tranparent areas (eyebrows, lashes etc) look like this.
Fugazi (without the aid of a safety net)
https://www.facebook.com/Fugazi3D
tastiger ( ) posted Wed, 30 March 2005 at 12:22 AM
Just checking on my terminology - it is the pubic hair morph that needs to be injected and set to 1 otherwise it just won't show up....
Robert A. Heinlein
Windows 11 Pro
Raven_Song ( ) posted Wed, 30 March 2005 at 2:17 PM · edited Wed, 30 March 2005 at 2:21 PM
Wow, thanks for all the replies. I never thought of some of that. I will give it a try and see if it helps. And a question ofr Fuzagi. Does that mean that I HAVE to have her at the default? I wanted her to have freckles at least on her face. Does this mean that with freckes, you cannot have eyebrows? I thought that was the point of the trans map.
Thanks everyone, I'll give some of this a shot. Oh and I am using Poser 5.
Message edited on: 03/30/2005 14:21
Raven_Song ( ) posted Wed, 30 March 2005 at 2:35 PM
Hey the pubic hair is fixed, thanks tastiger. But the eyebrows are still missing. If you want me to post a pic of her face, I can if you think it will help. Or if you need any other info? Should I just reset her to default and try again? I have the expansion pack too, that was where I was picking her eyebrow style. But they just don't appear. Thanks everyone.
Raven_Song ( ) posted Wed, 30 March 2005 at 2:40 PM
LOL! You are going to laugh! Same problem! For some reason, I had the eyebrows gone morph set to 1! WOW, I am a total moron. Thanks for the replies everyone, I am going to go hang myself now! Haha...
Fugazi1968 ( ) posted Wed, 30 March 2005 at 3:07 PM
:) glad its working Raven :)
tastiger ( ) posted Wed, 30 March 2005 at 4:00 PM
Don't worry - I've been around since Poser 3 and the "inject pubic hair" morph had me stumped for a while with V3.... Had exactly the same problem you did...
Robert A. Heinlein
Windows 11 Pro
Raven_Song ( ) posted Wed, 30 March 2005 at 6:38 PM
Well I am certainly glad that I am not the only one to have had this problem. If a veteran has done it, then I don't feel so bad. :) Thanks for all the help!
