Sat, Jan 11, 12:50 AM CST
Subject: Converging ducks - ecosystem + graph
yggdrasil ( ) posted Tue, 29 March 2005 at 8:03 PM · edited Sat, 11 January 2025 at 12:42 AM
How to get a gaggle (or is that only geese?) of ducks to swim towards a common point on the bank. Above is the graph for the Rotation - maximum angle value on the ecosystem. -- Mark
Mark
yggdrasil ( ) posted Tue, 29 March 2005 at 8:04 PM
Oh and notice the one duck on the far right who just HAD to be awkward...
Mark
sittingblue ( ) posted Wed, 30 March 2005 at 4:22 AM
That's brilliant work. Keep on dabblin' and sharin'. Charles
Charles
craftycurate ( ) posted Sun, 15 October 2006 at 6:13 PM
Has anyone managed to get this working? Is it possible to save it as a function and post it?
Thanks
Richard
quetzalcoatl1967 ( ) posted Sun, 02 September 2007 at 6:20 AM
Where is the arc sine in Vue 6?
nruddock ( ) posted Sun, 02 September 2007 at 7:44 AM
Quote - Where is the arc sine in Vue 6?
There isn't one (mislabeled in screenshot I suspect).
The node you want is the "Arc Cosine" one, which is a Math node.
quetzalcoatl1967 ( ) posted Sun, 02 September 2007 at 7:58 AM · edited Sun, 02 September 2007 at 8:00 AM
OK, I wasnt sure if it was mislabeled or if it was dropped in Vue 6 (edit: makes sense as the output of arccosine is 0 to pi, while arcsine is -pi/2 to pi/2)
Then there is that sentence "plugged into normalizer Y" but what I can do is plug the arc sine into the Y of the Decomposer. Is that a typo too?
Problem is I get some orientation, but only some of closer ones orient right, some of the closer ones orient wrong and the distant ones show strange patterns.
quetzalcoatl1967 ( ) posted Sun, 02 September 2007 at 8:24 AM
OK, there is something fishy here. First it works only in a 180° angle.
And there seems to be a strange offset. When I make it work at center it works, when setting a 25m offset in the constant the offset in the result is 50m
quetzalcoatl1967 ( ) posted Sun, 02 September 2007 at 8:58 AM
This is the pattern I get:
I dont know too much about vectors, probably it is intended to only cover 180° correctly. For this I used X instead of Y and 0 instead 0.5 for the rotation adjust. With Y and 0.5 the correctly adjusted instances are on the left.
And I made some more tests, vector offset has to be half the actual position, thats why I always got strange results. Probably a bug in VUE or inherent to the algorithm?!?
quetzalcoatl1967 ( ) posted Sun, 02 September 2007 at 9:31 AM
actually it is not a factor 2 in distance but whatever, in my scene I had to try until it worked, actually I had to vector was about 20x the position...or maybe I just understand that stuff wrong
