Wed, Feb 5, 3:14 AM CST
Renderosity Forums / Carrara
Welcome to the Carrara Forum
Carrara Free Stuff here.
Subject: help in carrara pls.
N-3D ( ) posted Wed, 30 March 2005 at 4:10 PM · edited Wed, 05 February 2025 at 3:14 AM
hi all i need know how i can export from Adobe Illustrator CS 11 AI format to carrara 4 when import AI format to carrara 4 gust i see the AI format box without the design i make in the Illustrator CS 11 thanks N-3D
mmoir ( ) posted Wed, 30 March 2005 at 4:16 PM
You can import ai files into carrara's spline modeler , drop in a Sline object , then File/Import a cross section or sweep path. I always use ai files 3.0 but others should work.
MarkBremmer ( ) posted Wed, 30 March 2005 at 4:21 PM
Hello N-3D, In Adobe Illustrator CS choose: Export>Illustrator Legacy (ai)>Version 8 or older. Mark
N-3D ( ) posted Wed, 30 March 2005 at 4:52 PM
ok thanks guys when i have layer in photoshop psd i open psd in Illustrator nad drop layer from psd in to new page in Illustrator and save it format ai i cant see design in carrara 4 now i need how i can save the ai with layer psd without the problems in lack of the appearance N-3D
MarkBremmer ( ) posted Wed, 30 March 2005 at 5:25 PM
N-3D,
Carrara will only import Illustrator paths into the Spline modeler, not images/bitmaps. Paths "Saved" in Illustrator will not work, they must be exported as Legacy AI.
If you want paths from Photoshop, choose the options shown above.
N-3D ( ) posted Wed, 30 March 2005 at 6:29 PM
hi i opened photoshop i followed the steps clarifier from you then i opened tllustrator doesn't appear only white page thanls N-3D
MarkBremmer ( ) posted Thu, 31 March 2005 at 5:17 AM
N-3D, What language do you speak? Let's get someone connected to you in the same language. I think that is why we are missing something. :) Mark
N-3D ( ) posted Thu, 31 March 2005 at 7:08 AM
hi mark see the links 1 - http://img16.paintedover.com/uploads/16/n1_1.jpg 2 - http://img16.paintedover.com/uploads/16/n2_1.jpg thanks for help N-3D
MarkBremmer ( ) posted Thu, 31 March 2005 at 7:25 AM
I see the problem.
Unless there is a path in Photoshop, no paths will be exported to Illustrator. Photoshop will not convert bitmaps into paths. You can trace the shape with a pen tool, however.
Vector masks need to be converted to a path prior to exporting.
N-3D ( ) posted Thu, 31 March 2005 at 11:53 AM
hi mark
MarkBremmer ( ) posted Thu, 31 March 2005 at 12:00 PM
2 ways: 1. select "fill cross section" in the Cross Section option dialog. This only works if the paths are joined. 2. make sure that the paths are actually joined. An open shape usually means the paths aren't connected.
N-3D ( ) posted Fri, 01 April 2005 at 6:42 PM
hi mark until now it empty i choose fill cross section as you told me truth i am not understand ( make sure that the paths are actually joined. An open shape usually means the paths aren't connected ) postponed the clarification from you thanks N-3D
N-3D ( ) posted Sat, 02 April 2005 at 10:44 AM
thanks mark it works now u r the best N-3D
