Wed, Nov 27, 9:01 AM CST
Subject: Trying IBL with AO and Shadowcatcher
ws ( ) posted Fri, 01 April 2005 at 9:32 PM · edited Sat, 23 November 2024 at 7:15 PM
Hello I really like new P6 options like integration of renderings with photos. There is my first attempt. I used two lights: IBL with AO and infinite for creation shadows consistent with shadows in the photo. For shadowcatching I used two boxes placed as floor and door. The result is maybe slightly too sharp (post filter size at 2) but for bigger renderings higher values may be a solution. I appreciate any comments and advices.
kuroyume0161 ( ) posted Fri, 01 April 2005 at 11:53 PM
  1. The shadow on the door would be much sharper - see the patio overhang for reference). 2. The shadows on the figure should be sharp/contrasted. Again, see the shadows of the 'real' objects in the photo. 3. To my eye, the lighting on the figure doesn't seem to match that of the sun in the photo. This could be because of the lack of shadow definition on the figure. It is an excellent start and, unlike some other composite's that I've seen, at least you got the general direction of the light mostly correct for the figure's shadow casting. The sun is lower than you think. Just look at the angle of the shadow cast onto the wall by the overhang as compared to that of your figure to the shadow on the door.
 -- Bjarne Stroustrup
xantor ( ) posted Sat, 02 April 2005 at 6:47 AM
If you make the figures texture a bit weaker, it would probably blend in better with the rest of the picture, too.
ws ( ) posted Sat, 02 April 2005 at 11:03 AM
Thanks for your replies. I have changed shadows parameters and adjusted the "sun position" as it was advised. And I changed colour of the light imitating the sun so as to match warmer look of the rest of the photo. The main point is, of course, that the same photo is for background and for IBL and it does not reflect the whole environment so it must be corrected by additional lights and simultaneously it decreases usefulness of IBL in this case.
kuroyume0161 ( ) posted Sat, 02 April 2005 at 12:14 PM
Better! :) IBL is definitely not an end-all of lighting in Poser. Remember that it is not HDRI, which actually contains extra-color information and uses it to get more realistic lighting. So far, I've found that complementing the IBL light with an infinite or point light at the same position as the greater light source (which, I'm guessing coincides with the IBL light direction (?)) compliments by adding the contrast, highlights that IBL seems to remove. So, although additional lights ideally decrease IBL usefulness, I think that they are a necessity. Think of IBL as the HDRI ambient color information and the other lights as pseudo HDRI luminance information.
ws ( ) posted Sat, 02 April 2005 at 1:54 PM
Thanks :) You are right. I reach the same conclusion about positioning the lights in IBL mode. I have also discovered that additional (not IBL) lights don't create shadows when IBL is on (I am not sure if it is a real discovery or I simply missed something reading the manual). I use position of IBL light for creation of shadows and - of course - so as to create proper highlights the infinite light has to be in the same position. Despite wrong assumptions - infinite for shadows, I get the proper result - infinite for highlights. After 2 year break in working with Poser and after moving directly from P4 to P6 I consider P6 possibilities as really amazing. Thank you for your comments
gtrdon ( ) posted Sat, 02 April 2005 at 6:20 PM
Wow That pic is fabulous did you make your own stuff for the background??? I am impressed
ws ( ) posted Sun, 03 April 2005 at 4:37 AM
The background is a photo taken during my holidays.
gtrdon ( ) posted Sun, 03 April 2005 at 9:17 PM
Could have fooled me! Great Compositing! Where is that South America?(Spanish Adobe Looking)
ws ( ) posted Mon, 04 April 2005 at 9:35 AM
Thanks. It is south of France.
kuroyume0161 ( ) posted Mon, 04 April 2005 at 10:04 AM
Ah. I was thinking Spain. :)
