Thu, Dec 26, 12:33 PM CST
Poser - OFFICIAL F.A.Q (Last Updated: 2024 Dec 26 9:02 am)
Subject: I need Surf Trunks for David
Larry-L ( ) posted Sun, 03 April 2005 at 3:04 PM · edited Wed, 25 December 2024 at 11:39 PM
Greetings, I've hit Daz,RDNA & Here looking for surf trunks for David. Does anyone know if soemthing is available? Pay or free, it doesn't matter. Boxer shorts don't cut it. I've tried the stock P5 swim shorts but I can't make'em fit just right.
nruddock ( ) posted Sun, 03 April 2005 at 3:14 PM
You could try using his BodySuit.
The Planar mapped version has the material zones that would make it easy to get close to what you want just by setting materials.
Alternatively you can make a transmap to get any shape you want on either the Planar or Millenium mapped version.
Tyger_purr ( ) posted Sun, 03 April 2005 at 4:18 PM
Attached Link: http://www.poserworld.com/store/ProductInfo.aspx?productid=PW-SOCCER-DAVID
Did you check out the Football(Soccer) uniform from PoserWorld? I have some textures for them that are free.
My Homepage - Free stuff and Galleries
hauksdottir ( ) posted Mon, 04 April 2005 at 12:17 AM
First... by surf trunks, do you mean really baggy "jams" with drawstring waist and loud patterns designed to scare away sharks and small children? Carolly
Larry-L ( ) posted Mon, 04 April 2005 at 7:14 AM · edited Mon, 04 April 2005 at 7:16 AM
Attached Link: http://www.renderosity.com/viewed.ez?galleryid=924672&Start=1&Artist=Larry%2DL&ByArtist=Yes
Yep, those are the ones; however, I just decided to use the standard P5 surf trunks and fiddle with them to get a close fit. Then by making body parts invisible and a little touchup in PS I think it came out just fine.
Message edited on: 04/04/2005 07:16
hauksdottir ( ) posted Mon, 04 April 2005 at 10:03 PM · edited Mon, 04 April 2005 at 10:04 PM
Looks good as far as the trunks go. Is that hand position a signal? Something like "call me"?
I'll agree with the others that you need better sand... there are some desert freebies with sand texture and, IIRC, ynsaen's Island over at Oddditty has nice sand, too... and the feet need to sink into it a bit, AND some footprints should be behind him. Otherwise, he isn't anchored to this earth. After you get the texture, you can widget with the shadows. It is possible that the shadow catcher might help here? I do like his tan (yum) and the POV.
Carolly
Message edited on: 04/04/2005 22:04
Larry-L ( ) posted Mon, 04 April 2005 at 10:18 PM
Before it was "call me" is was a surfer sign kinda like "okay". I'm working on the sand right now which I created as a texture in Terragen and did some post work in PS. It came out pretty good. How do you create footprints in sand? Thanks
hauksdottir ( ) posted Tue, 05 April 2005 at 4:38 AM
Attached Link: http://www.sxc.hu/browse.phtml?DREAMID=46ea37475ad301ad90b753e6b51eebfd&f=search&txt=footprints&w=1
First... look at some photos of footprints to see how the little bits get kicked up as the foot leaves. It is different for wet sand and for dry sand. I just typed in "footprints" at the stock exchange site: http://www.sxc.hu/browse.phtml?DREAMID=46ea37475ad301ad90b753e6b51eebfd&f=search&txt=footprints&w=1 Then you get to decide if you want to do a quick bit of postwork in PhotoShop, or if you want to make a displacement map and try to position it. Rendering once with the map and once without, you could eliminate prints from in front of him with a mask. Being in sand, precision is a disadvantage! It should look a bit messy. ;) Carolly
