Poser - OFFICIAL F.A.Q (Last Updated: 2024 Dec 26 9:02 am)
Attached Link: http://www.poserworld.com/store/ProductInfo.aspx?productid=PW-SOCCER-DAVID
Did you check out the Football(Soccer) uniform from PoserWorld? I have some textures for them that are free.My Homepage - Free stuff and Galleries
Attached Link: http://www.renderosity.com/viewed.ez?galleryid=924672&Start=1&Artist=Larry%2DL&ByArtist=Yes
Yep, those are the ones; however, I just decided to use the standard P5 surf trunks and fiddle with them to get a close fit. Then by making body parts invisible and a little touchup in PS I think it came out just fine.Message edited on: 04/04/2005 07:16
Looks good as far as the trunks go. Is that hand position a signal? Something like "call me"?
I'll agree with the others that you need better sand... there are some desert freebies with sand texture and, IIRC, ynsaen's Island over at Oddditty has nice sand, too... and the feet need to sink into it a bit, AND some footprints should be behind him. Otherwise, he isn't anchored to this earth. After you get the texture, you can widget with the shadows. It is possible that the shadow catcher might help here? I do like his tan (yum) and the POV.
Carolly
Message edited on: 04/04/2005 22:04
Attached Link: http://www.sxc.hu/browse.phtml?DREAMID=46ea37475ad301ad90b753e6b51eebfd&f=search&txt=footprints&w=1
First... look at some photos of footprints to see how the little bits get kicked up as the foot leaves. It is different for wet sand and for dry sand. I just typed in "footprints" at the stock exchange site: http://www.sxc.hu/browse.phtml?DREAMID=46ea37475ad301ad90b753e6b51eebfd&f=search&txt=footprints&w=1 Then you get to decide if you want to do a quick bit of postwork in PhotoShop, or if you want to make a displacement map and try to position it. Rendering once with the map and once without, you could eliminate prints from in front of him with a mask. Being in sand, precision is a disadvantage! It should look a bit messy. ;) CarollyThis site uses cookies to deliver the best experience. Our own cookies make user accounts and other features possible. Third-party cookies are used to display relevant ads and to analyze how Renderosity is used. By using our site, you acknowledge that you have read and understood our Terms of Service, including our Cookie Policy and our Privacy Policy.
Greetings, I've hit Daz,RDNA & Here looking for surf trunks for David. Does anyone know if soemthing is available? Pay or free, it doesn't matter. Boxer shorts don't cut it. I've tried the stock P5 swim shorts but I can't make'em fit just right.
