Sat, Nov 9, 7:58 PM CST
Poser - OFFICIAL F.A.Q (Last Updated: 2024 Nov 09 6:42 pm)
Subject: need help with P5 face room please
amberlover13 ( ) posted Sun, 03 April 2005 at 5:24 PM ยท edited Sun, 03 November 2024 at 5:35 PM
I'm having trouble in the face room. Trying to make a custom face from images, but no matter what I do I can't see the bottom of the room. All the other pallets in P5 are movable except for the one in the face room where you put the front and side view of the texture you want to make. I can see the full face one fine, but it cuts me off half way down the side one. I've tried adjusting my screen size, and moving the window around, but still can't get to it. Does anyone have a suggestion? Thanks
geep ( ) posted Sun, 03 April 2005 at 6:36 PM
What screen size are you using? .... ;=]
cheers,
dr geep ... :o]
edited 10/5/2019
fls13 ( ) posted Sun, 03 April 2005 at 6:39 PM
You need to be using 1024x768
geep ( ) posted Sun, 03 April 2005 at 6:48 PM
FYI - Dr Geep uses 1152 x 864 because ... cheers, dr geep ;=]
cheers,
dr geep ... :o]
edited 10/5/2019
amberlover13 ( ) posted Sun, 03 April 2005 at 6:49 PM
Thanks! That fixed it. For some reason mine was set at 800x600.
geep ( ) posted Sun, 03 April 2005 at 6:52 PM
Yup, it's fer sure ... 800 x 600 will chop off the bottom half of the Face Room. The part on the left side can not be moved. Sorry 'bout dat. ;=[
cheers,
dr geep ... :o]
edited 10/5/2019
amberlover13 ( ) posted Sun, 03 April 2005 at 7:05 PM
This helps a lot. I've been moving pallets all over the place just to see what I'm doing.... I had a recent crash and had to have someone reinstall another hard drive, and when I got my computer back, he'd changed most of my settings. Changing the screen size made a big difference. Thanks!
xantor ( ) posted Sun, 03 April 2005 at 7:13 PM
Does that still happen with poser 6 and its face room?
geep ( ) posted Sun, 03 April 2005 at 7:28 PM
Probably ... I can let you know tomorrow ... unless someone else already knows. ;=]
cheers,
dr geep ... :o]
edited 10/5/2019
fls13 ( ) posted Sun, 03 April 2005 at 8:26 PM
Nice tip, I'll have to try the expanded pixel setting. :O) I've always kept my screen rez at 1024x768 because my site stats tell me that's what most visitors use, but that size does get a bit crowded. Is P6 any better?
Acadia ( ) posted Sun, 03 April 2005 at 9:16 PM ยท edited Sun, 03 April 2005 at 9:20 PM
That screen size, is that something you set in Poser? If so how? Or are you referring to the main screen resolution of your computer? If it's computer screen resolution, I work on my laptop which has an LCD screen and you can't set it for some resolutions otherwise it's blurry and distored. Currently mine is set at: 1280 x 1024
Message edited on: 04/03/2005 21:20
amberlover13 ( ) posted Sun, 03 April 2005 at 10:31 PM
We're talking about screen resloution. After I got my computer back from the "expert" everything was changed and I couldn't figure out how, until now. Changing the resolution from 800x600 back to 1024x768 made a huge difference. I also couldn't figure out why I was no longer able to "dock the pallets" in Photoshop anymore when I could before. I had just chalked it up to the fact that I had to do a total reformat. But even that's working normal again.
