Mon, Feb 10, 3:43 AM CST
Subject: Can I make a single Full Body morph that includes other FBMs?
DrowVampyre ( ) posted Mon, 04 April 2005 at 1:30 AM ยท edited Mon, 10 February 2025 at 3:37 AM
Hi. I'm trying to make a single FBM that will apply all the effects of several other FBMs. Is there any way to do this? I'm running Poser 6, by the way.
anxcon ( ) posted Mon, 04 April 2005 at 2:14 AM
as in creating a face on V3, using a dozen dials then make one dial that apply all the effects as 1? spawn morph target in the menu i think?x_x unless im thinking wrong command......been up too long but yes its possible x_x
DrowVampyre ( ) posted Mon, 04 April 2005 at 2:22 AM
Well, sort of. What I'm trying to do is make a single morph dial that wil change standard V3 into a character I created using morphs from several packages, most of which are FBMs themselves.
amberf ( ) posted Mon, 04 April 2005 at 3:08 AM
Yes you can. Set the morphs you want to whatever dial setting and then from the Figure menu, click on Create Full Body Morph and give it a name. You'll then have a dial in the 'body' part for that morph combination. Remember to set all the dials back to zero before using the fbm one.
DrowVampyre ( ) posted Mon, 04 April 2005 at 3:23 AM
I thought that would work, but when I tried it, the only thing it works for is the face. It doesn't seem to want to apply the other full body morphs.
caulbox ( ) posted Mon, 04 April 2005 at 3:29 AM
Attached Link: http://www.renderosity.com/messages.ez?ForumID=12356&Form.ShowMessage=2186284
My comments in the linked thread may help.
DrowVampyre ( ) posted Mon, 04 April 2005 at 5:14 AM
Ah, that helps a bunch. Thank you very much!
unzipped ( ) posted Mon, 04 April 2005 at 4:18 PM
bookmark
