Sat, Feb 8, 6:46 PM CST
Subject: How do u avoid bump map artifacts in render??? please help...
Boomtrooper ( ) posted Tue, 05 April 2005 at 8:26 PM · edited Sun, 19 January 2025 at 3:08 AM
I need to add bumps maps to a product i am making and the renders are just awfull i get render artifacts that are not good looking it must be something really small that i need to do but i would like to know what... Can someone give me answers of how they dealt with that type of problem.. here is a render so that you can see the problem i have to resolve... thanks
randym77 ( ) posted Tue, 05 April 2005 at 8:32 PM
What bump setting are you using? Poser uses very small bump settings. Like, under 1. Well under. Skin should be something like 0.01. I usually have it set to less than 0.1, even for fairly rough objects.
Little_Dragon ( ) posted Tue, 05 April 2005 at 8:40 PM
Reduce the JPEG compression?
maxxxmodelz ( ) posted Tue, 05 April 2005 at 8:56 PM
Yeah, it looks like poor antialiasing due to low resolution or highly compressed bump map. Less compression and higher res would solve it most likely.
nerd ( ) posted Tue, 05 April 2005 at 10:34 PM
Forum Moderator
If you are using P5 or higher turn texture filtering on. Nerd3D
R_Hatch ( ) posted Wed, 06 April 2005 at 12:28 AM
I highly recommend using PNGs for bump, displacement and transparency maps. You cannot get a true black or white with JPEG.
Nance ( ) posted Wed, 06 April 2005 at 2:15 AM
[slaps forehead] Can't believe that the 'no true black areas with jpeg compression' thing has never occured to me. DOOH!
