Poser - OFFICIAL F.A.Q (Last Updated: 2025 Feb 16 10:02 pm)
As Stewer suggests, increasing bias and decreasing range in AO helps with problems like that. Sometimes you have to play with the AO settings to get what you want. :-) "I haven't had much luck using skin shaders in P6." There was a thread about this. Apparently the skin shader in P6 was changed, and if you import older scenes that were shaded in P5 with that shader, it will render wrong. Was the skin shader you're using applied in P5 originally?
Tools : 3dsmax 2015, Daz Studio 4.6, PoserPro 2012, Blender
v2.74
System: Pentium QuadCore i7, under Win 8, GeForce GTX 780 / 2GB
GPU.
No, they're not all useless. Most work perfectly fine. However, the skin node in P6 was changed, so that's one which won't translate properly from P5. The rest should be fine.
v2.74
GPU.
Ooops... I read your post wrong. You're talking about MAT files with the skin shader in them. Sadly, those WILL be screwed up.
What you might be able to do is replace the skin nodes that are in the MAT files with P6 skin nodes on all the bodyparts, then save the material to the library. P6 allows you to save the ENTIRE figure's materials (all bodyparts) to a "material collection", which is just like having a MAT file, only you apply it now from the material room.
Message edited on: 04/06/2005 06:50
v2.74
GPU.
Well, I agree it's a bit of a hassle to "swap" out the skin shader on every body part, but once it's done, you never have to do it again. As mentioned, save the figure's new materials using the new 'material collection' feature, and you can add it again any time with one click.
v2.74
GPU.
Attached Link: http://www.renderosity.com/messages.ez?Form.ShowMessage=2187315
There's some info in this thread. I wonder... Does deleting that original skin node and replacing it with a new one solve the problem? You should be able to wire it the same as it was previously.Tools : 3dsmax 2015, Daz Studio 4.6, PoserPro 2012, Blender
v2.74
GPU.
There may be more changes in the skin shader. Lots of folks don't like the changes. If you all file bugs (Be nice!) they might change the values to line up better with the old values. But I imagine you will probably still wan't to plug a diffuse node into the skin input somewhere. If you are all are really nice you migh get the coders to include a "legacy" skin node. Nerd3D
i keep getting black spots and polygons all over figures
when using firefly, tried for 2 days and overnite to no avail,plus it is still to damn slow for my needed workflow,
so i am back to using the p 4 renderer for now,but that means i cant use the realskin shaders etc by faceoff and other merchants-any suggestions for settings would be a help-i've got a 10,000+ page comic i started drawing 15 years ago and have been doing it over in 3d for 4 years now i would like to get it rendered before i'm 90!
