Fri, Jan 24, 10:43 PM CST
Subject: Another question about Poser textures...
blaufeld ( ) posted Tue, 05 April 2005 at 4:20 AM ยท edited Fri, 24 January 2025 at 9:56 PM
I was playing with adding some bump functions to obtain a realistic bump for Poser skin textures, but at no avail... Some suggestions? Thank You!
TheWingedOne ( ) posted Tue, 05 April 2005 at 6:18 AM
Could you please clarify which version do you use (Vue 5 or Vue Infinite)? Otherwise it's a little bit difficult to help. ;)
blaufeld ( ) posted Tue, 05 April 2005 at 1:13 PM
Right... Vue 5. :)
TheWingedOne ( ) posted Wed, 06 April 2005 at 1:08 PM
Have you downloaded the actual update from e-on's website. Maybe this fixes your issue. I'm on Vue5Infinite so I can only guess what's wrong.
Have you downloaded the actual update from e-on's website? Maybe this will fix your issue. I'm on Vue5Infinite so I can only guess what's wrong.
blaufeld ( ) posted Thu, 07 April 2005 at 12:29 AM
Well, I was not talking of having a prob... but that I would like suggestions on how to make a realistic bump function for human skin... :)
TheWingedOne ( ) posted Thu, 07 April 2005 at 1:56 AM
Attached Link: http://www.renderosity.com/messages.ez?Form.ShowMessage=1281461
Now I got it. ;) I usually set the bump gain to 0.1 or even lower depending on the POV and size of the figure. I also edit the highlights, since the imported figures usually have a dark grey which makes the skin look kinda dull. You might also have a look at Djeser's skin mat settings thread at: http://www.renderosity.com/messages.ez?Form.ShowMessage=1281461 Hope this helps. :) Phil
TheWingedOne ( ) posted Thu, 07 April 2005 at 1:57 AM
...one more thing. I usually use the bumpmaps that come with the figure and if none is available I use the color map as a bump map as well.
blaufeld ( ) posted Thu, 07 April 2005 at 9:55 AM
Thanks!!!
