well each object has a collission setting and youll find that in the object parameter dials box under properties. double click any object or body part to open the box. also, the documenbt tools (around the preview pane), the sixth bubble from the top is to turn on collission detection in the preview pane - but dont do that until your posing is done. if you have that turned on and your still posing, it can make posing a bit annoying since poser wil studder slightly if you collide something into something else and its trying to calculate whether or not it should be there. so use the bubble-button after youve finish setting your poses/animation.
Okay, I've read in the manual about this function, and can't find it anywhere. Can somebody point it out to me?
