Poser - OFFICIAL F.A.Q (Last Updated: 2024 Nov 10 6:07 am)
"To avoid trouble, additional Runtimes should contain only the Geometries, libraries, and textures folders (of course, the libraries folder should contain all its nested folders.) If you copy your existing Runtime to the new Runtime folder, please first remove all other folders from it (other than Geometries, libraries and textures) before merging the Runtimes." Partial quote from CL tech support. (The last line is what got my attention) This might be my problem. I think I added the whole folder and maybe it is just getting confused. I have a lot of stuff in there. And there are probably plugins and such interferring with P6 finding what it needs. Just goes to show you that I really need to read all the directions! :)LOL! I'll post again if I get it fixed. Thanks Tammy :)))
Okay, like I said earlier, "I really need to read all the directions"! If you are having this same problem, remove everything from your P5 runtime folder except Geometries, libraries and textures. Then use the ADD RUNTIME feature (the plus sign at the bottom of your library palette). Mine is running perfectly now. :))) Thanks to anyone that tried to find an answer for me! Tammy
Hi all! I just got my new P6 up and running and everything was fine with the installed content. When I went by CL's instructions on loading the content from my P5 runtime, it can't find any of my textures. Is this related to the memory bug I have been reading about or is it a fluke and I just need to reinstall/change something? Oh, I did the ADD RUNTIME feature to load the P5 stuff I've collected. If there is a thread please just point me in that direction. Thanks Tammy :)
