Tue, Jan 21, 6:23 PM CST
Poser - OFFICIAL F.A.Q (Last Updated: 2025 Jan 21 4:30 pm)
Subject: How do I get rid of the mesh floor?
BJsHaven ( ) posted Thu, 07 April 2005 at 8:57 PM · edited Tue, 21 January 2025 at 6:22 AM
Could someone tell me how I get rid of the mesh floor? Thank you. BJ
PhilC ( ) posted Thu, 07 April 2005 at 9:03 PM
Go to Display/Guides and uncheck Ground Plane.
cindyx ( ) posted Thu, 07 April 2005 at 9:39 PM
Thanks for asking the question. I wanted to know that too. And thanks for the answer.
Fazzel ( ) posted Thu, 07 April 2005 at 10:55 PM
Here is sort of the opposite question. How do I put a texture on the floor in P6 like I was able to in P5? In P5 the floor was sort of a prop. In P6 it just appears to be guidlines.
pokeydots ( ) posted Thu, 07 April 2005 at 11:53 PM
I'd like to know why I can't see the ground texture in preview? I have it set for full texture shaded.]I applied a material to the ground in the materials room, and made sure I had the ground set to visible, but I still couldn't see it :( Thanks
Poser 9 SR3  and 8 sr3
Processor Type:  AMD Phenom II 830 Quad-Core
Hard Drive Size:  1TB
Processor - Clock Speed:  2.8 GHz
Operating System:  Windows 7 Home Premium 64-bit
Graphics Type:  ATI Radeon HD 4200
System Ram:  8GB
nruddock ( ) posted Fri, 08 April 2005 at 2:13 AM
The Ground Plane in P6 has the "Shadow_Catch_Only" option turned on.
You need to goto the Material Room and uncheck the box.
You'll also need to reconnect the texture to the Diffuse input on the surface.
nruddock ( ) posted Fri, 08 April 2005 at 2:31 AM
You'll also need to change the display style (Element Style) from "Wireframe" to "Use Document Default" or "Textured".
pokeydots ( ) posted Fri, 08 April 2005 at 3:27 AM
Thank you that worked! ;o)
System Ram:  8GB
BJsHaven ( ) posted Fri, 08 April 2005 at 6:53 AM
Thanks so much for all your info. Appreciate it. I am going from Poser 4 to Poser 6 and it sure is different. Didn't like Poser 5, it hung up my computer too much so I went back to Poser 4. BJ
Tirjasdyn ( ) posted Fri, 08 April 2005 at 9:58 AM
Attached Link: http://fnproductions.net/graphics/tutorials/poser6
I've added these to the faq!
Tirjasdyn
