Fri, Jan 10, 7:12 PM CST
Poser - OFFICIAL F.A.Q (Last Updated: 2025 Jan 10 1:16 pm)
Subject: Pixelated P6 Render problem
Magik1 ( ) posted Sun, 10 April 2005 at 3:23 PM · edited Fri, 10 January 2025 at 6:47 PM
Hi everybody Can one of you good people shed a little light on what's going on here? this pic is rendered in P6 on the 'Final' render setting with 'smooth polygons' ticked.The whole figure is 3500pxls high and 300 pixls per inch. This section of the picture is taken in Potoshop CS at 100%. WHAT'S WITH ALL THE PIXLES????? Thanks for any help
templargfx ( ) posted Sun, 10 April 2005 at 3:27 PM
what file format did you save the image in? try saving as TIF format
TemplarGFX
3D Hobbyist since 1996
I use poser native units
167 Car Materials for Poser
Magik1 ( ) posted Sun, 10 April 2005 at 3:33 PM
Its a JPEG. I'll try a TIF but it actually looks like this in the poser render window as well. Thanks templargfx
operaguy ( ) posted Sun, 10 April 2005 at 3:49 PM
This setting: "300 pixls per inch." has no impact on the quality of your image whatsoever. Smooth polygons does not influence graniness. as with the other two people above, you probably rendered to a jpg saved at a low quality. Render to TIF as suggested and report back. Is the red lighting intended? ::::: Opera :::::
STORM3 ( ) posted Sun, 10 April 2005 at 3:58 PM · edited Sun, 10 April 2005 at 3:59 PM
Under:
Render/Render Dimensions have you set your height-width and resolution?
Message edited on: 04/10/2005 15:59
alamanos ( ) posted Sun, 10 April 2005 at 4:02 PM
i think it's your texture. Regardeless of the resolution you choose. if your source texture for v3 is of low quality, you'll have pixelation.
Magik1 ( ) posted Sun, 10 April 2005 at 4:02 PM
Yeah, I'm STUPID !!! Your absolutely correct guy's. 'Just saved it as a TIF from P6 and it's now just fine. Odd though, I've never come across this problem before and I alway's save as JPEG. (Highest res in PS) Thank's a lot for the help. Yes, the red light is intended, Take a look at the finished piece which should be in the 'PinUp' gallery by tomorrow.
operaguy ( ) posted Sun, 10 April 2005 at 4:06 PM
k
