Poser - OFFICIAL F.A.Q (Last Updated: 2025 Jan 10 1:16 pm)
what file format did you save the image in? try saving as TIF format
TemplarGFX
3D Hobbyist since 1996
I use poser native units
This setting: "300 pixls per inch." has no impact on the quality of your image whatsoever. Smooth polygons does not influence graniness. as with the other two people above, you probably rendered to a jpg saved at a low quality. Render to TIF as suggested and report back. Is the red lighting intended? ::::: Opera :::::
Yeah, I'm STUPID !!! Your absolutely correct guy's. 'Just saved it as a TIF from P6 and it's now just fine. Odd though, I've never come across this problem before and I alway's save as JPEG. (Highest res in PS) Thank's a lot for the help. Yes, the red light is intended, Take a look at the finished piece which should be in the 'PinUp' gallery by tomorrow.
