Tue, Nov 26, 2:18 PM CST
Subject: 2 little tricks
Pollee ( ) posted Wed, 13 April 2005 at 6:37 PM ยท edited Tue, 26 November 2024 at 12:22 PM
I found these little tricks: If you want an ecosystem to surround a sphere use a mix material with 2 ecosystems but before you apply the 2nd ecosystem flip the object upside down. The 2nd trick is if you want to use pictures or tools that only work on non procedural terrains do so and then in the terrain editor switch back to procedural. It works most of the time and you can have the best of both terrrains features this way. If anyone has anything to add or subtract from these tricks please do so.
naji_s ( ) posted Wed, 13 April 2005 at 7:31 PM
It's not in type? where can i find it?
yggdrasil ( ) posted Wed, 13 April 2005 at 7:38 PM
Vue 5 Infinite only. From the advanced material editor.
Mark
TerraDreamer ( ) posted Wed, 13 April 2005 at 8:21 PM
Thanks for the tricks, Pollee. I've FINALLY found the time to sit down and start using Infinite. I must say, the first time I used ecosystems today I was floored!
Pollee ( ) posted Wed, 13 April 2005 at 8:54 PM
Me too. I can't stop experimenting. I have one big problem. Can you distribute objects in an ecosytem with a distance to object below node (similiar to shore foam tut by Monsoon)? I can't get it to work the same way?
SAMS3D ( ) posted Thu, 14 April 2005 at 3:38 AM
I have to try this one for sure. Thanks Sharen
Monsoon ( ) posted Thu, 14 April 2005 at 5:36 AM
Excellent tips Pollee.....you can distribute eco objects with a distance to object below node....Just make sure you have decay near foriegn object turned off...or it won't populate.
