Sat, Feb 8, 11:49 AM CST
Photography F.A.Q (Last Updated: 2025 Feb 03 6:38 am)
Subject: ML-L3 Nikon Remote for N65 camera... how's it work?
jks ( ) posted Thu, 14 April 2005 at 11:05 PM ยท edited Sun, 02 February 2025 at 8:44 AM
So I bought the remote for my N65 camera and the battery is fresh and everything... but it doesn't seem to work. Is there something additional I need for my camera to make it click or something? Don't understand why it doesn't work. Would help if the remote had a manual I suppose.
Michelle A. ( ) posted Fri, 15 April 2005 at 5:36 AM
There's probably a setting in your camera that you need to change in order for the remote to trigger the shutter.... check the camera manual, I bet it's in there. I'm not familiar with the N65 but the D70 is like that.....
I am, therefore I create.......
--- michelleamarante.com
jks ( ) posted Fri, 15 April 2005 at 5:21 PM
haha, trippy. totally wouldn't expect accessory instructions to be in the actual camera manual. that's pretty smart. reduces the amount of manuals :-P Thanks :-D
DJB ( ) posted Sat, 16 April 2005 at 12:58 AM
Speaking of remotes for a D70....do they work good. I think I want one as you can not use a cable release on these new cameras,and I miss that function.
"The happiness of a man in this life does not consist in the absence but in the mastery of his passions."
Michelle A. ( ) posted Sat, 16 April 2005 at 6:42 AM
It works well enough Doug..... it uses the same ML-L3 that jks has.... I found that some days it seems less sensitive than others... where I can point it at the camera from any direction and it works, and others where it needs to be pointed directly at that front element, for it to see/read the beam and trip the shutter. It was frustrating for me too when I got mine because like jks, I couldn't figure out how to get it to work.... I thought for sure I had gotten a defective one. But hours later I decided to take a peek in the camera manual and oh boy there it was...... press the shooting mode button and dial in delayed remote or quick response remote... smacks head
