Wed, Jan 22, 8:25 PM CST
Poser - OFFICIAL F.A.Q (Last Updated: 2025 Jan 22 7:49 pm)
Subject: Mac to PC converter?
jt1161 ( ) posted Fri, 15 April 2005 at 9:19 PM · edited Thu, 01 August 2024 at 1:12 PM
Is there such a thing for Poser files?
galactron22 ( ) posted Fri, 15 April 2005 at 10:33 PM
There's a PC to Mac converter in the freestuff under utilities, But since 99.999999999% of all poser items are specifically made for PC there might not be one
Ask me a question, and I'll give you an answer.
Ghostofmacbeth ( ) posted Fri, 15 April 2005 at 11:06 PM
But the Mac one converts to PC :)
kaveman ( ) posted Sat, 16 April 2005 at 12:46 AM
What P5 or P6 files need converting? I thought we were file compatible now? Or is this just for stuff older than P5?
mateo_sancarlos ( ) posted Sat, 16 April 2005 at 1:14 PM
There is such a thing (MaConverter), but it runs in OS 9 (or maybe classic mode).
KDoug ( ) posted Sat, 16 April 2005 at 9:00 PM
Are you having a certain problem, jt1161? I wasn't aware of any problems where PC users needed to convert Mac-created Poser content, but maybe one of us can help if you give us some more details.
jt1161 ( ) posted Sun, 17 April 2005 at 8:16 AM
I downloaded a freebie zip called Pixie Playground and the Readme indicates it was created on a mac - to convert the prop files to PC prior to using. I just had never heard of doing this before. Usually it is the other way around :)
Ghostofmacbeth ( ) posted Sun, 17 April 2005 at 9:18 AM
Most time the creators on a Mac just make it PC for ease of use.
KDoug ( ) posted Sun, 17 April 2005 at 4:33 PM
Jt1161, just try loading it and seeing if it will work. I suspect it will load for you with no problem. But if it doesn't, I got no clue! Sorry I couldn't be of more help.
jt1161 ( ) posted Tue, 19 April 2005 at 6:25 PM
Thanks for trying, I truly apppreciate the effort. If my poor puter ever decides to work again I will let you know about it. I did manage to unzip it, and had to backdoor to open the readme file. Word wouldn't recognize it for some reason, so I renamed it as a txt file and opened it with notepad. Now the puter won't start, so I can't check to see if Poser recognized the files or not. Always something, lol.
KDoug ( ) posted Tue, 19 April 2005 at 9:09 PM
Whoa! Sorry to hear that. I hope you can get it working again without too much trouble.
Jim Burton ( ) posted Wed, 20 April 2005 at 7:14 PM
Mac files differ from PC files mainly because they have a 512 byte (if I recall) header added at the front of the file, that tells the Mac what kind of file it is, and what program runs it, stuff like that. There should be PC utilities (not Poser ones, general ones) if you look around for stripping these off. Mac Converter works fine, but only on a Mac, as noted. There is also a difference in how carrage returns are added to text files, too.
kaveman ( ) posted Thu, 21 April 2005 at 11:17 PM
Jim, that may be so for the old OS9 files but we've been standard UNIX for the 5 years. Any one still making Mac files for OS9 users is way out of date.
Jim Burton ( ) posted Fri, 22 April 2005 at 11:02 AM
Yeah, I not too current on Macs, as I know longer use one. So they changed the file format?
kaveman ( ) posted Fri, 22 April 2005 at 3:54 PM
We have full backwards compatibility, but the "preferred" method is to use the standard files with the correct extensions. It's completely up to the Application how it reads in the files. The same goes for EOL markers, OSX will read the standard, Mac, Unix or Windows formats, if the App makes use of the correct calls. There is a LOT of confusion in this area with Content for Poser, and I still haven't found an OSX answer. Are the 2 versions of Poser now File compatible? I don't know about others but I'm not buying content because I don't know which version to buy. If I buy the Mac version, it's OS9 and a real pain to convert to OSX, if it's Win and they use an .exe "Installer" then the installer won't run, even if the files are compatible. Sadly the Mac Compatibility FAQ over at the Mac Forum is still OS9 centric and promotes products that aren't available on OSX.
MarianneR ( ) posted Sat, 23 April 2005 at 12:30 AM
kaveman: I have no problems with content for P5 and P6 as long as I stay away from exe's. If the items are truly made for P5-P6 they are identical for Windows and Mac, no conversion neccessary. If you come across something with rsr's instead of png's for the thumbnails, Maconverter will convert it running in Classic mode. Also there is a utility by fmorgan that will make png's out of rsr's. There is one simple version in freestuff and one in the marketplace here. Python is a problem though: scripts that use Tkinter won't work on the mac, like the Real Skin Shader by face_off. Content for Poser 4 Mac works in Mac P5-P6 also, Poser makes the png-file for the thumbnail.
