I don't know exacttly what you mean, but my late hair (Hollywood hair, SMV hair, etc) starts with a cylinder with another cylinder inside it, then it is mapped, then it is bent to form one curl (with one end burried slightly inside the head, as you said), then it is cloned around the head, modifing each one in turn. Actually the above sounds a lot easier than it really was to do it, I had to do about 5 hairset before I got one I liked!
![file_144762.jpg](https://live.cdn.renderosity.com/forum/_legacy/file_144762.jpg)
I was surfing some eye plastic surgery sites for anatomical research and learned something interesting. The upper eyelid has roughly 100 lashes. The lower only has half that, though. Many of the P4 transmaps try to make them the same, resulting in unusually bushy lower lids. The above shows the default P4 Woman map, using Nod's Sarah map for the lashes. The below shows a customized version of Sarah where every other lash was faded out (some traces still appear, sorry). FWIW, Vicky's lash maps are correct in this manner.
