Tue, Jan 14, 11:41 PM CST
Poser - OFFICIAL F.A.Q (Last Updated: 2025 Jan 14 12:25 pm)
Subject: P6 Face Room ?
SVicious ( ) posted Mon, 18 April 2005 at 7:29 PM · edited Tue, 14 January 2025 at 11:19 PM
I have been trying to work with the room, I am determined to not give up, the problem I seem to be coming up with is when I import a picture the top part of the geometry is off the image (top green dot) How can I fix it so when the imported picture has all the green dots? Also whats the best size picture to use when importing it into the face room?
xantor ( ) posted Tue, 19 April 2005 at 1:53 AM
If you get face room pictures with poser 6, try and make the pictures you use as close to the same proportions as these ones as possible (using a paint program). The bigger picture that you can use the better.
SVicious ( ) posted Tue, 19 April 2005 at 1:56 AM
the problem i am having is I can't see the top green dot only the right and left top dots, what size works cause I tried 525 x 525 the same size it tells me to convert it to when i apply it to the figure. Are you saying the picture should basically take up the whole pic with your face?
xantor ( ) posted Wed, 20 April 2005 at 5:14 AM · edited Wed, 20 April 2005 at 5:15 AM
You don`t have to make the picture the size it says, you can make it bigger and it usually is better to use a bigger picture.
The first problem might be caused if the face does fit the whole picture, it should have a blank area around the head.
Message edited on: 04/20/2005 05:15
