Fri, Nov 8, 12:08 AM CST
Renderosity Forums / Carrara
Welcome to the Carrara Forum
Carrara F.A.Q (Last Updated: 2024 Nov 05 6:06 am)
Carrara Free Stuff here.
Subject: Primivol shadows?
sailor_ed ( ) posted Fri, 22 April 2005 at 11:09 AM · edited Wed, 30 October 2024 at 8:35 AM
My tests seem to show that an object in a Primivol plugin "fog" does not cast shadows on the fog. Am I doing something wrong or is this just the way it works? Thanks in advance. ED
julien_chaplier ( ) posted Fri, 22 April 2005 at 12:05 PM
Hello Ed,
Volumetric objects in Carrara can't cast shadows (Primivol as well as Carrara's volumetric primitives). It a limitation due to the current implementation of this kind of primitive inside Carrara: volumetric primitives are rendered in there own space, appart from the scene. It's this same limitation that makes the distant lights the only one available for volume lighting. I sent these remarks to Eovia when I was working on Primivol and I hope the SDK will show some improvment for Carrara 5.
Regards,
Julien
Kixum ( ) posted Fri, 22 April 2005 at 2:42 PM
That's interesting because I think the fire primitive in Carrara does cast a shadow. -Kix
-Kix
sailor_ed ( ) posted Fri, 22 April 2005 at 4:34 PM
Thanks for the reply!
falconperigot ( ) posted Fri, 22 April 2005 at 4:56 PM
Shadows from clouds? No problem! ;-)
sailor_ed ( ) posted Fri, 22 April 2005 at 8:10 PM
The problem is to get the clouds (primivol fog) to accept a shadow like the 3d shadows in a light cone. I wasn't very clear.
falconperigot ( ) posted Sun, 24 April 2005 at 1:04 PM
Ed, apologies, you were perfectly clear. I was simply demonstrating a trick to get shadows from clouds - as Julien says, it's not possible directly but by coloring the light to black and outputting a light map using Baker I produced this image. I've no solution to your problem, I'm afraid. Unless you can use metaballs to fake it using shadow-catchers or something.
